turbo automatic
Old Apr 18, 2009 | 03:00 AM
xplayer325's Avatar
turbo automatic
ok I just got a 16g turbo given to me is there gonna be anything that I'm gonna have to do to the auto tranny to hold the power besides a tune?
Old Apr 18, 2009 | 03:34 AM
HunterKiller89's Avatar
nope. tranny cooler wouldnt hurt tho.
auto's good for 350tq atleast, tho its only rated for 315tq
Old Apr 19, 2009 | 09:41 PM
CobaltTSX's Avatar
Trans cooler for sure!!!! Don't even think twice!! Also I would recommend researching trans fluids to find the one with the best cooling and lubrication under heavy load. B&M Trick Shift is what a lot of drag guys use but not to sure how our tranny's will act on it.
CobaltTSX's Avatar
Old Apr 19, 2009 | 11:26 PM
'06 and up cobalts come with the best tranny fluid out there. I'f you're an '05 though, then I'd swap to mobil 1 synth auto tranny fluid if you're gonna swap fluids. Tranny cooler is only necessary depending on how much you drive. Most of my daily trips (anything under 30 minutes of driving) and my tranny doesnt even reach operating temperatures. It takes a while for all 14qts to heat up.
Old Apr 19, 2009 | 11:50 PM
xplayer325's Avatar
If I got one what kind of tranny cooler would you recommend
Old Apr 20, 2009 | 01:11 AM
Hayden makes some good coolers. Try and get one that only cools the tranny fluid when its hot. The one I have (which is cheaper) will cool the fluid regardless of what temperature it is, so it takes longer to reach operating temperature.
Old Apr 20, 2009 | 08:55 PM
Dimitri Manesis's Avatar
What about internals??? Will he need to swap anything inside, i.e. cams, pistons, rods, etc.
Old Apr 20, 2009 | 09:24 PM
Originally Posted by Dimitri Manesis
What about interals??? Will he need to swap anything inside, i.e. cams, pistons, rods, etc.
stock internals are good for about 230whp (not nitrous), though 220whp is a safer number. If he wants more, rods and pistons should be done, then he's good for near 500whp
Old Apr 21, 2009 | 04:38 AM
xplayer325's Avatar
with this turbo that I have I would be lucky to be pushing 220 whp so I dont think I'll need to do that. Another question do I need to replace the intake manifold?
Old Apr 21, 2009 | 12:59 PM
i would recommend using the 2.4 intake manifold, as its stronger and flows more, and its also one solid piece. Our stock manifold is 2 pieces effectively glued together, and higher pressures can break the pieces apart.
this kit includes everything needed to convert to the 2.4 manifold:
http://www.crateenginedepot.com/stor...P1817C137.aspx
Old Apr 21, 2009 | 02:47 PM
xplayer325's Avatar
ok thanks thats what I figured but I thought maybe I could get away with it.
Supercharged06SS
Dec 11, 2022 04:47 PM
maliki778
Oct 1, 2015 07:39 PM
MrInsanityWolf
Sep 29, 2015 04:54 PM
