Turbo Grind Cams for 07+ 2.2
Old Sep 25, 2009 | 01:41 AM
06cobaltindallas's Avatar
ok guys i have just got an update on my build and have two pics of a set of comp cams
turbo grind cams with the cam sensor pressed on.
enjoy
Old Sep 25, 2009 | 07:12 PM
Jn2's Avatar
Jn2
looks good when will everything be done and running by?
Old Sep 26, 2009 | 12:23 AM
j27's Avatar
j27
where did you get them
Old Sep 26, 2009 | 12:24 AM
ilovecars's Avatar
god dam i wish i had the money.
Old Sep 26, 2009 | 02:06 AM
06_ion2's Avatar
got blower cams in my 2.2 they sound awesome at idle. you will love yours.
Old Sep 26, 2009 | 02:16 AM
these r the 03 to 06 eco cams. u can get them through allecotec or turbotechracing
i had Marty Ladwig from gm racing do this for me since his race team is doing all my head work.
but you have to cut down the intake cam to fit into the 07 head. and then press that cam senor on.
charged me 200 for it
Old Dec 1, 2009 | 12:32 AM
jerseyfatboy's Avatar
hey man is the sensor that needs 2 b pressed on jus a gm part?
also...u think i culd send my cams (wen i get them) to the guy who wrkd on urs to do the same?
Last edited by jerseyfatboy; Dec 1, 2009 at 12:32 AM. Reason: Automerged Doublepost
Old Dec 1, 2009 | 01:51 AM
no i dont think u can order just the sensor by itself. best bet is to try and find an intake cam that has it at a junk yard.
ya u can email him. look up marty ladwig on myspace.
thats the easiest way u can get in touch with him
Old Dec 1, 2009 | 01:53 AM
where'd u get urs? nd i dnt hav a myspace lol
Old Dec 1, 2009 | 11:02 AM
i sent mine personally thru a shop by my work that races against marty, so they know him.
but if you can email him im pretty sure u can get it done
mladwig@satx.rr.com
thats his other email
Old Dec 1, 2009 | 07:29 PM
2007victoryred's Avatar
DAMN!!
Old Dec 1, 2009 | 09:23 PM
mladwig@satx.rr.com
o man thnx alot 4 that ill def. hit em up
Old Dec 2, 2009 | 12:41 PM
ml2242's Avatar
dope cams.
Old Dec 2, 2009 | 04:44 PM
thanks.
Old Apr 7, 2010 | 07:00 PM
Cobalt629's Avatar
do i have to do that same **** to put camms in my 2008 2.2L?
Old Apr 7, 2010 | 07:03 PM
conerboner's Avatar
sexy!
Old Apr 7, 2010 | 08:13 PM
redcobalt07's Avatar
so you bought cams for an 05 06 cobalt then get the sensor pressed on?
Old Apr 7, 2010 | 10:29 PM
the cams that i got were the ones that comp sells which are for the older eco heads 04-06.
what has to happen is a machine shop has to take accurate measurements as to where the sensor is placed on the factory cam and then measure that onto the aftermarket cam. since the intake cam is shorter on the 07 and up they would cut off the excess cam to the right size for it to fit, since we dont have the old power steering box attached to the head. once it is cut the sensor is pressed onto the new cam.
Old Apr 7, 2010 | 10:31 PM
ok thank you, so how good of an option do you think that is? like how well will that hold up in the engine?
Old Apr 7, 2010 | 10:39 PM
what exactly are you looking for?
they will hold up just fine if you are talking about the structual integrity of the cam.
from the reading i have checked out from multiple forums is that the turbo grinds will generally reduce the rpm time for turbo spool by 1k in most cases. so if you have a gt35r that spools at say 4500 then itll drop it to around 3500 or somewhere in that range
Old Apr 7, 2010 | 10:40 PM
well before I was looking for a stage 1 set for my bolt on build but now I'm supercharged so would I need blower cams?
Old Apr 7, 2010 | 10:48 PM
ya blower cams would be your best bet if you arent looking for crazy power. stage 1 is bolt quality, stage 2 is going to be associated with head work, and stage 3 is for the upper hp range. i think it stretches into the 8k rpm if im not mistaken. but i would recommend the blower cams.
and i got my cams from allecotec.com, but you can also get them through ttr as well
Old Apr 7, 2010 | 10:54 PM
lwpmoon's Avatar
Ok. I'm running a gt28 that spools around 2.8k and thats good for me. Is the turbo grind still the best for making power above 7k or a different grind?
Old Apr 7, 2010 | 11:00 PM
what are your power goals? they are still probably the best because the next cam up is the stage 3's and like i said they are for really high top end power. if your looking for anywhere between 3-375 hp then ur fine with the turbo's
Old Apr 7, 2010 | 11:04 PM
lwpmoon's Avatar
Possibly touching low 400's with a nice low end. I want it to be drivable and then turn the boost up for the track.
