Turbo Grind Cams for 07+ 2.2
Old Apr 7, 2010 | 11:05 PM
06cobaltindallas's Avatar
ya then you'd be fine with the turbo grind then
Old Apr 7, 2010 | 11:12 PM
lwpmoon's Avatar
Ok. Thanx for the help
Old Apr 7, 2010 | 11:30 PM
redcobalt07's Avatar
hmm idk if i should get aftermarket cams though cause i'm already stage 2 and pushing my max power ratings as it is
Old Apr 7, 2010 | 11:46 PM
06_ion2's Avatar
I see no point they are flowing more than stock anyways.
Old Oct 18, 2010 | 10:55 PM
Mike85220's Avatar
A couple questions...
I am assuming this can be done with stage 1 cams also, correct?
How much did he charge you to machine the cams and then press the sensor on?
Thank you!
Old Oct 19, 2010 | 10:54 PM
dandaman15's Avatar
Thank you!
From what I read in another topic you dont need the sensor pressed on if you tune through Trifecta. He disables it so It wont throw a CEL and will work properly. Im still not sure if its okay to run the 03-06 cams with out the sensor and everything will be okay. I just know it can be done. If anyone that has done it can shed more light on it that would be great.
Old Oct 22, 2010 | 10:09 PM
yes it can be done with any stage of cam. he charged me i think it was around 200 for it to be cut and pressed on. because the 03-06 cams are longer on the intake
Old Oct 22, 2010 | 10:30 PM
conerboner's Avatar
Can someone verify this? i want to get turbo grind cams for my 07 2.2. Do I need to get the sensor pressed on or can I just tune for it?
Old Nov 30, 2010 | 02:37 PM
ml2242's Avatar
Seems like a bad idea to just tune out a sensor.. to definitively tell you, we would need to know the exact function of the cam positioning sensor otherwise it could be like tuning out your 02 sensor or something retarded like that
Old Nov 30, 2010 | 02:46 PM
hawlyns711's Avatar
I heard without that sensor on the cam that the start-up cranking time is just increased, like you have to turn the motor over several more times so the pcm can tell where the engine is in its timing sequence. I may be wrong though, just what I read when I was researching cams.
Old Nov 30, 2010 | 02:50 PM
  #36
ml2242's Avatar
Could possibly end up dumping tons of fuel trying to start it every time then? The idea of blower cams sounds great to me as thats the last thing I can do before going forged. But I'm not wasting $1000 on cams+tune for a nice sounding idle & 20whp. Sucks once your dyno tuned you really don't want to have to re-tune for a single modification.
Old Dec 8, 2010 | 01:25 PM
  #37
oldskool's Avatar
To the OP - did you install aftermarket springs? With out at least the supertech 78lb kit your running a risk of float or even snapping a stock spring with the increased lift. On all their spec sheets, comp states valvesprings are required.
You might get away with it for a while on stock springs, but smashing a valve and having to tear down is an unnecessary risk IMO.
Old Dec 8, 2010 | 03:36 PM
  #38
NWAE Cobalt's Avatar
i have comp stage 2 and managed to float mine...
your actually fine if you dont over rev the engine..and my cyl head is shaved...so im even closer
although u do run the risk of breaking one...
best bet is to just replace them...cheap insurance really :P
Supercharged06SS
Dec 11, 2022 04:47 PM
maliki778
Oct 1, 2015 07:39 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
