turbo timer install help
ok well ive done alot of google and research and countless hours looking at wire diagrams but has any one installed one yet or some one already made a forum abou this any one has any help
i made a thread on this aswell if you search for it on this forum you will find one thread that had pics of where to connect everything but there were too many wires to really make anything out, but there as some members that have them, most of them thru their car alarms, but i think one guy got the pen style one from HKS
lot of turbo timer manufacturers (sp) make vehicle specific harness that plug into the car. the timer itself is generic....its the harness which is a bitch to find.once you do, plug the harness in and the timer just wires into the harness...if that makes sense lol
hope this helps
http://cgi.ebay.ca/MINI-TURBO-TIMER-...1%7C240%3A1318
hope this helps
I want the HKS Type-1 Turbo timer
http://www.hksusa.com/products/?id=845
Especially since my aeroforce interceptor just broke about 30 min. ago. My turbo was installed friday, drove for 3 hours and gone no more interceptor. Took it out of the pod and reconnected it in a few times but it's done
For now I'll just sit in my car for a minute before I shut it off
Did not need them since I got the alpha turbo kit. My cig lighter and Aeroforce gauge both don't work so later today I'll have to check the fuses. Something is wrong here
Anways Back on Topic
If anyone has installed a turbo timer without running into problems with the GM Passive Lock let us know
UPDATE Monday Evening
Replaced the fuse for the Cig Lighter (15Amp) and my lighter and aeroforce interceptor work now
I have too many 12v. accesories and I had no idea that the ODB2 and Cig lighter share the same fuse. Gonna have to sell the aeroforce
well the thing is yea the passive lock might be a problem but since the gray wire that it comes with and most of the turbo timers that i have installed goes to the ebrake. but i have a kill switch installed in my car would that make a diffrence in it but mostly i just need the wire diagram
