UniChip and Turbo Tech Racing needs your help
We were contacted by UniChip as we need a photo, here is what they requested:
Unichip wants to make a harness for the cobalts, they think they have the harness already sourced. However they would like to get a picture of the stock ecu next to the plugs for the ecu. This would greatly help the cause. Pics are needed for the 2.0/2.2/2.4
Bottom line they stated this in an email:
"Well, we are looking for a picture of the ecu on a cobalt ss and a non ss cobalt, so we need pics of both, they should look nearly identical if not identical. But basically we need to see if there are 2 or 3 plugs on it"
PM or email me at Aaron@TurboTechRacing.com if you can be of any help
Originally Posted by tallyphotog
Would have thought there was pictures in the build book?
Lift your hood on the driver side you'll see where the red battery connection post is then there is a plastic piece in front of that it is curved grab it by the sides and pull towards you slightly and then lift up and you will see your ecu and there it is about 6x6 with fins on it it should have 3 plugs. I never checked my 2.2 when I had it bit all the plastic I mentioned is the same.. hope this helps
