UniChip and Turbo Tech Racing needs your help
Old 03-22-2006, 03:54 PM
TurboTechRacing's Avatar
We were contacted by UniChip as we need a photo, here is what they requested:
Unichip wants to make a harness for the cobalts, they think they have the harness already sourced. However they would like to get a picture of the stock ecu next to the plugs for the ecu. This would greatly help the cause. Pics are needed for the 2.0/2.2/2.4
Bottom line they stated this in an email:
"Well, we are looking for a picture of the ecu on a cobalt ss and a non ss cobalt, so we need pics of both, they should look nearly identical if not identical. But basically we need to see if there are 2 or 3 plugs on it"
PM or email me at Aaron@TurboTechRacing.com if you can be of any help
Old 03-22-2006, 05:46 PM
IonNinja's Avatar
does that mean tuning options in the near future?
Old 03-22-2006, 05:48 PM
ecoteched's Avatar
Maybe be dumb question but are they the 2 computer things right next to the fuse box?
Old 03-22-2006, 06:10 PM
cvenom2122's Avatar
Thumbs up
they better make this for 04 redline to dmanit
Old 03-22-2006, 06:15 PM
That is most likely the air bag modual you are seeing.
Old 03-22-2006, 06:24 PM
2K5SS/SC?'s Avatar
Unichip = tuning! Sweet!
Old 03-22-2006, 08:24 PM
shortyheldberg's Avatar
Aaron I e-mailed you the pictures did you get them also where are you located ???
Old 03-22-2006, 09:15 PM
Loacated in MN, Recieved the pics, thanks for the help, it was passed on to UniChip.
Old 03-28-2006, 01:08 PM
tallyphotog's Avatar
Would have thought there was pictures in the build book?
Old 03-28-2006, 02:29 PM
CivicKiller98's Avatar
build book has a lot of info but its a little light on the pics. im surprised the link to download it hasnt been posted yet.
Old 03-29-2006, 11:45 PM
Shamrock's Avatar
where exactly is the ecu these guys want? I want to send pics of the sedan, is it under the hood, in the fender, or the interior plugs?
Old 03-30-2006, 12:32 AM
Lift your hood on the driver side you'll see where the red battery connection post is then there is a plastic piece in front of that it is curved grab it by the sides and pull towards you slightly and then lift up and you will see your ecu and there it is about 6x6 with fins on it it should have 3 plugs. I never checked my 2.2 when I had it bit all the plastic I mentioned is the same.. hope this helps
Old 03-30-2006, 04:58 AM
Shamrock's Avatar
helps a ton, helps the sedans get a new ecu I'll be happy thanks!
Old 03-30-2006, 11:23 PM
WadaSty51's Avatar
pardon my ignorance but what exactly does a unichip do
Old 03-31-2006, 03:18 PM
CJ Thunder's Avatar
If you do post them up here to I want to see something as well.
Old 03-31-2006, 11:05 PM
Shamrock's Avatar
Since this is for Unichip, I'll let Aaron make the call on posting up the pics.
and Unichip makes ECU programming/flashing programs and utilities.
Supercharged06SS
12-11-2022 04:47 PM
RaginChopsuey
10-27-2015 01:27 PM
justinchinn
10-02-2015 12:18 PM
maliki778
10-01-2015 07:39 PM
SSLOW06
10-01-2015 07:21 PM
Quick Reply: UniChip and Turbo Tech Racing needs your help
