Whats The Purpose...
If this site, had a member of the month. I would choose you 007 for your outstanding courtesy and respect for other members lmao .....I always felt like a badass buying octane booster for my other car
Well, if you were tuned for 91 or 93, it would be because you were advancing the timing in order to increase the cylinder pressure to increase horsepower. If you were to go back to 87, you would be running more unstable fuel with the increased heat of the added timing which could detonate.
So, no you could not go back to 87 unless you got retuned and retarded the timing back down.
The reason you have 91 rather than 93 octane is because of the elevation you are at. Higher elevations do not need as high of octane levels
I do have a question of my own though (this question probably belongs in the hypermiling section, but oh well).
My plans are solely for fuel economy (K&N drop-in for now...will get an intake later, LSJ DP, LSJ cat-back, and either leave the manifold alone or go with something like the Racing Solutions header) and fun in the curves (front strut tower, rear sway, SS/TC struts/shocks).
Can I get a Trifecta tune done and not increase the required octane (this probably doesn't make sense...I'm thinking, what's the point in getting a tune if you're not going to run higher octane fuel)? Or, can I get the same kind of MPG with 91/93 as I would with 87 (assuming I drive the same)?
Thanks for the clarification, I wasn't sure if the computer would automatically take the lower octane into account and retard the timing or not (since there was mention of the 2 tables). I have a lot to learn in terms of fuel and timing and what not.
Last edited by 007CobaltLS; Apr 4, 2009 at 01:31 AM. Reason: Automerged Doublepost
Can I get a Trifecta tune done and not increase the required octane? Or, can I get the same kind of MPG with 91/93 as I would with 87 (assuming I drive the same)?
One word of advice, stay away from the 2.4 manifold if you want to keep good mileage. I used to get 39/40 mpg hwy with bolt ons and a careful watch of the rpms, afterwords I was seeing maybe 32 at most. It REALLY shifts the powerband up, you want all the low end grunt you can get for fuel economy.
After all is said and done, if I can get at least a 15% gain in economy, I'll be happy. In the winter I'm getting ~25 because of warming my car up and the additives they put in the gas....summer time I average 28-30 (this is mixed with a bit more city driving). I think the only highway trip I did, I averaged almost 33/34. So If I can get about 3 MPG more in my mixed driving, I'll be happy.
On 87 octane I dyno'd at 360WHP,91 octane I dyno'd 393WHP.
just kidding my car will prolly never see the rollers haha.I use 91 just cause I feel it burns cleaner.I scoped my cylinders and they look purty @ 38,000 miles.
If you really want MPG mods, get an underdrive pulley, lightweight rims, and tires with a low rolling resistance. if manual, get a lightweight flywheel as well.
As far as the computer learning down octane levels, some will throw you completely into a low octane table which is much lower than a reduced 87 octane tune. Other PCMs can learn values between the low and high octane tunes in order to achieve the best spark conditions for the fuel present.
thank you capt obvious. :-P doesn't change there are two tables for the capability of tuning both high octane and low octane.
And Sentry, for bolt-ons including intake mani, you can run 87 just fine after tune. Got this info from Vince himself.
When Trifecta does the tune, they mess w/ the high octane table. anyone that gets the trifecta tune is getting their high octane table changed as part of the process. So are you talking about a tune minus one of the fundamental portions of a ecm tune?
ill talk to vince about it and see what he says...
boosthard05
Aug 29, 2010 01:57 PM
