2.2l LAP all motor
yeah i posted this cuz i knew i would get so many mixed thots. lool but right now the plan is to find a 2.4 tb and mani then install alll my parts n tune
mods will follow Injen CAI/SRI, 2.4 TB, 2.4 Mani, Badmab Header, ZZP 2.5 downpipe and Magnaflow 2.5 catback exhaust!
so ...
throttle body
header (depending on sai)
down pipe
catback
maybe the mpx crank pulley
intake
tune...
thats it for now....
Trust me many 2.4 guys are waiting for cams from zzp as well. though if the lap is really a mini le5 then you should be able to run the zzp lnf exhaust cam
i removing my SAI. and id like to find someone who knows someone that works at gm and that they could verify it! and i wouldnt put a crank pulley. heard they screw up our motors
Obviously if your going for best bang for the buck turbo or nitrous is the best way.
All-motor is 100x more rewarding in the end IMO. Efficency is much more important when your all-motor.
My car makes 169whp and runs 13.8 @ 100, not bad for a little stock looking purple sunfire
mods will follow Injen CAI/SRI, 2.4 TB, 2.4 Mani, Badmab Header, ZZP 2.5 downpipe and Magnaflow 2.5 catback exhaust!Obviously if your going for best bang for the buck turbo or nitrous is the best way.
While i think the badmab is excellent bang for the buck when going for that high of a hp number id recommend a better header. While they havent been dyno proven yet the zzp longtube header should make more power than the badmab. And since 200whp is a high number for an NA ecotec then you need every last bit you can get.
put an le5 in and call it a day, you can buy a used one for ~$500 best money well spent
zzp going to get it right? or just another failure in the le5 cams?
Last edited by 09blackonblack; Feb 28, 2011 at 06:58 PM. Reason: Automerged Doublepost
I just got a new head from a guy on here and was thinking it might be from a 2.4, are the 2.2 heads and 2.4 interchangeable? It was running fine besides a misfire in cylinder 2 due to bad valve seats and determine if I should put my old head back on after machining or use the one I just bought(possibility 2.4)
ThoR294
Oct 4, 2015 08:44 PM
