2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
2.4 throttle body
Old Mar 13, 2012 | 07:03 PM
heyheyhey666's Avatar
2.4 throttle body
I read a lot of post from the community but i'm still not sure about what 2.4 throttle body i should get for my LAP. Should i get a 2.4 throttle body from a 2008 cobalt cause they have 6 pin and i was wondering if they are other models that have the same throttle. I saw this TB on ebay and i was wondering if its gonna fit and if its gonna improve performance on my cobalt
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
The last thing i wanted to know is if theres an aftermarket TB i can get that is going to be as good as 2.4 TB from a 2008 cobalt
Old Mar 13, 2012 | 10:17 PM
bluebalt07's Avatar
Yes that one will work, although you should swap to the 2.4 intake manifold first to get the best gains. No aftermarket throttle bodies but you can use an LSJ throttle body. For this though you would need to rewire for it because it is an 8 pin. Either way you WILL need a tune when you switch throttle bodies
Old Mar 13, 2012 | 10:21 PM
CobaltItaliano's Avatar
First, make sure you get ones with the correct matching pins, or yea like said above, you will have to rewire. That TB in the link is pretty fd up. I picked one up from a member on here for 65$ shipped in better condition then that. So just look around and be patient.
And I think he has a 2.4 IM on there already cuz hes a LAP engine. Not sure though
Old Mar 14, 2012 | 01:24 AM
Clifton's Avatar
He needs the 6-pin from a 2008. And yes the manifold is a 2.4 just revised. I have both
Old Mar 14, 2012 | 01:37 AM
I read a lot about that and im happy that you confirm everything! Getting a Tb shipped from another member is more complicated because i live im Canada...
Old Mar 14, 2012 | 12:20 PM
i recieved a tb from a member in canada for $65 shipped. lol. fedex does international shipping to your door. cost about $12 for me when I made the purchase.
Old Mar 14, 2012 | 07:07 PM
Clifton's Avatar
What's good about the 2008 6-pin bolted over the LAP is that it doesn't require a tune. I'm not tuned (yet) and she's been running like a champ, no CEL, no Limp mode. A tune helps though.
Old Mar 14, 2012 | 07:20 PM
nhanson's Avatar
LSJ throttle body!
Old Mar 14, 2012 | 08:15 PM
mongorat427's Avatar
What size is that big throttle body they use on the turbo swaps ? I think it comes on the Canyon 2.9 or 4.2
Old Mar 14, 2012 | 08:20 PM
nhanson's Avatar
Originally Posted by mongorat427
what size is that big throttle body they use on the turbo swaps ? I think it comes on the canyon 2.9 or 4.2
ls4?
Old Mar 15, 2012 | 08:02 AM
I have one thats 6 pin and larger than the 2.4 Looks to be off a 07 and up. V6 maybe. Bolts right on the lnf intake but you would need to port the **** out of the manifold to match it up. I think its off a 3.5 or 3.6
Old Mar 15, 2012 | 11:25 AM
Well... I think its better to get a 2.4 IM from a 2008 cobalt
Old Mar 15, 2012 | 01:58 PM
Figured it out . Used on a bunch of engines 3.1 3.5 3.6 4.3 to mention a few
Old Apr 14, 2012 | 08:39 PM
2009CobaltLT's Avatar
So for reference, the LSJ does not bolt up, but the 2.4 does? And how much bigger is the LSJ than the 2.4, worth rewiring?
Old Apr 14, 2012 | 10:39 PM
bluebalt07's Avatar
It's like 4 mm bigger I think. I believe the 2.2 is 58.something mm, the 2.4 is around 64, and the LSJ is around 58. That's just going from memory so I don't know exactly what each is
Old Apr 15, 2012 | 12:08 PM
nhanson's Avatar
Just stick with the 2.4
Old Apr 15, 2012 | 11:25 PM
A 6 pin 2.4 from an 07 should just be plug and play on the LAP, right? Or only the 08 tb?
Old Apr 16, 2012 | 01:47 AM
Clifton's Avatar
2008 only
Old Aug 31, 2012 | 11:18 PM
Crav3's Avatar
I wanna get the 2.4 tb and a friend has his 2.4 tb but he's an 06 ss/na will it fit on mine?
Old Sep 1, 2012 | 01:06 AM
cobalt523's Avatar
FNG question, what do you mean by pin?
Old Sep 1, 2012 | 01:15 AM
Ceej's Avatar
The number of pins on the sensor
Old Sep 1, 2012 | 01:26 AM
Crav3's Avatar
Do i need to re wire it or can i get a 6 to 8 pin connector?
Old Sep 1, 2012 | 01:38 AM
you will need a rewire i dont think zzp sells there adaptors anymore
Old Sep 1, 2012 | 01:43 AM
Ceej's Avatar
You can definitely still get the adapter. No re wiring required
Old Sep 1, 2012 | 02:49 AM
Crav3's Avatar
Yea saw the adapter on Ebay lol by zzp i think but it's $40
DarrenGC
Dec 24, 2021 01:55 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
yellow dragon
Sep 28, 2015 09:49 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
