2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
200?
Old Aug 5, 2012 | 11:07 AM
LS6Rally's Avatar
Originally Posted by Tjolley
ask zzp if there mounts work with ur 2.2 if they say yes get a Le5 pull ur head off u 2.2 and put it on the 2.4 block and drop that thing in in the car..the only thing is that i would find out if the 2.2 and 2.4 use the same flywheel. that might be ur only problem.
no need to swap heads, they are the same Part Number
Originally Posted by Crav3
Wow this is interesting so can i use a lnf head on a 2.4? Just wondering lol
no, the LNF is Direct Injection, you cannot use that head on your LE5. Supposedly the Exhaust cam is a better cam and can be swapped into the LE5, but i havent looked into this
Old Aug 5, 2012 | 12:00 PM
nhanson's Avatar
I still want to know if i can use ZZP 2.4 cams on my LAP
Old Aug 5, 2012 | 12:03 PM
royce777's Avatar
^me too
Old Aug 5, 2012 | 02:36 PM
LS6Rally's Avatar
I dont see why you couldn't, the LAP and LE5 share the same part number for the bare head, so the bearing/journal sizes would also be the same. when doing the ZZP cams you should use the 78 or 82# valves springs anyways so those wont matter. the only thing you may need to check is piston to valve clearance, but i dont see it being an issue as the LE5 runs more stroke and a higher compression ratio. if it was you could most likey just get a thicker head gasket..
Old Aug 5, 2012 | 03:11 PM
bratboy90's Avatar
NHanson is ready to go E85 and blow up that POS LAP.
Old Aug 5, 2012 | 04:02 PM
nhanson's Avatar
Well see what happens during the winter.
Old Aug 5, 2012 | 05:10 PM
royce777's Avatar
wonder if zzp wants to experiment on a LAP ?
Old Aug 5, 2012 | 05:27 PM
nhanson's Avatar
ill be the guinea pig! I have almost all of their parts in my car.
I emailed them asking if it works in a LAP
Old Aug 5, 2012 | 05:32 PM
royce777's Avatar
first all motor LAP, hmmmm
Old Aug 5, 2012 | 05:33 PM
nhanson's Avatar
Well i have the M62 on my car but cams wont matter for that
Old Aug 5, 2012 | 05:37 PM
  #36
Crav3's Avatar
I would like cams for my lap too :/
Old Aug 5, 2012 | 05:58 PM
  #37
breds2k's Avatar
give up and go turbo. im completely lost interest after i did intake/exhaust/2.4IM and tune and got such a minimal increase. Think of the time and energy to get to 200 hp and then you pull up to a light and a 60 year old lady smokes you in a stock malibu. Happened to me. Hated life.
Old Aug 5, 2012 | 06:02 PM
  #38
nhanson's Avatar
Sort of true. You probably gained a good second in 1/4 and picked up 30whp or so.
I also got wasted by a malibu...it had 3 extra people in it too when i was just bolt ons of course
Old Aug 5, 2012 | 09:19 PM
  #39
bluebalt07's Avatar
LE5 should work on the LAP. I could swear I read that somewhere but just going by the fact that all the other head components are the same, there's no reason they shouldn't
Old Sep 2, 2012 | 07:15 PM
  #40
09LAP's Avatar
WOW that shiz is crazy. i had my 2.2 lap dynotuned when i was on leave in okc, i had a broken radiator fan witch only let me get 3 pulls in before she got too hot. im an N/A setup with 155WHP i didnt keep the graph cuz i was gonna throw on a few more bolts and fix the fan then go back for another run. I'd get on the dyno soon and get up on the top of that list real quick but im still deployed. When i get back ill def post up my stats for you fellas.
Old Sep 4, 2012 | 09:49 AM
  #41
cleanxfe's Avatar
what are your mods so far?
Old Sep 4, 2012 | 07:39 PM
  #42
09LAP's Avatar
Badmab shortty, connected to ZZP's 3" downpipe (with highflow cat). 3" pipe all the way back, magnaflow 14"X8" resinator, 5"X8" oval magnaflow muffler (she purrs). ported the block slightly where the header connects 1/8th" or so, head intake port 1/16th", intake manifold port (both sides 1/16th") K&N typhoon with larger sized filter. Oh and upper engine mount from TTR. when i get back i hope to throw on the
LSJ throttle body, lightweight alt pully, and a more radical exhaust port.
Old Sep 5, 2012 | 08:55 PM
  #43
noorj's Avatar
Originally Posted by elecblue06
yea on a really high reading dyno
LOL
I think every time someone mentions 200whp this comes up.
Anyways after I get my clutch in and lightweight flywheel, I'm going to go E85 and see if I can get some more timing out of it. Maybe make 200 on a dyno where people will stop bitching about
Old Sep 5, 2012 | 10:33 PM
  #44
09LAP's Avatar
Originally Posted by noorjariri
LOL
i feel ya
camaromanss1992
Oct 1, 2015 10:51 PM
Stuff
Oct 1, 2015 05:47 PM
footballplaya3k
Sep 28, 2015 11:14 AM
riceburner
Sep 27, 2015 11:10 PM
n20saturn
Sep 21, 2015 01:50 AM
