2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
different heads?
Old Apr 5, 2011 | 02:15 PM
07Maliboo's Avatar
different heads?
I'm lookin to see what you guys can tell me here. WOuld there be any benefit to any head swaps from any of the other cobalt motors?
Old Apr 5, 2011 | 02:16 PM
the_cobalt_kid's Avatar
AFAIK all gen II ecos use the same head... but if im wrong someone please correct me. i know you can't use a gen I on a Gen II or vice versa do to DI and VVT.
Old Apr 9, 2011 | 10:41 AM
NJHK's Avatar
Really...no. Like said, most are the same or similar (throughout the ECOTECs Gen II).
Even if you got a ported and polished head done, it costs a lot, its not worth anything unless you're getting camshafts done with higher duration / lift and even on top of that, its not worth it unless you're revving higher. All those head modifications ultimately shift your powerband upwards so you can make more HP but you need the RPMs to do it.
In my opinion, its only truely worth it on the ECOTECs if you are doing forced induction due to you being able to take advantage of the higher air volume capabilities OR doing a crazy N/A setup. Other than that, you're wasting your time and money. I'm speaking from experience.
Old Apr 10, 2011 | 09:01 AM
07Maliboo's Avatar
thanks for the info.
Old Apr 10, 2011 | 10:32 AM
NJHK's Avatar
You're welcome
Jan 12, 2016 12:01 AM
ineedacobaltss
Nov 7, 2015 02:25 PM
Trav3480
Oct 1, 2015 08:17 PM
Sep 28, 2015 12:51 PM
