2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Downpipe
Old Mar 6, 2011 | 06:45 PM
DavidLaMattina's Avatar
Downpipe
I thought downpipes were only for Turbo cars? Will this fit my non turbo 2.2?
Cobalt & Ion ---> ZZ Performance
Old Mar 6, 2011 | 07:09 PM
cobalt2010's Avatar
yes sir. direct fit replacement.
Old Mar 6, 2011 | 07:10 PM
outtamymind's Avatar
downpipe = catalytic convertor pipe
Old Mar 6, 2011 | 07:15 PM
Gotcha, so heres my second question... lets say I got that ZZP downpipe - would it bolt up to the rest of my stock exhaust? like wouldnt the flange sizes be different etc?
Also, if I went catless, is there any harm in that? Codes? Car running rough? Fail emissions?
Old Mar 6, 2011 | 07:18 PM
TommyP's Avatar
AWD > FWD
If you go catless, you will fail emissions if they use an 02 sensor. You may get a cel, but that can be tuned out. I would personally get a high flow catted downpipe on a 2.2, catless is gonna sound raspy.
Old Mar 6, 2011 | 07:22 PM
Well they offer a MagnaFlow cat pre-welded into the downpipe for an extra $50... should I just go that route?
Old Mar 6, 2011 | 07:24 PM
TommyP's Avatar
AWD > FWD
That'd probably be your best bet. A bit more refined sound, and you should be able to pass inspection, and you won't get a cel.
Old Mar 6, 2011 | 07:27 PM
Awesome, thanks for the help man. Now i'm trying to figure out what route I want to go for an exhaust.
Old Mar 6, 2011 | 07:29 PM
the flange to the catback should bolt up. the flange to the manifold might not depending on what you get. before i purchased i would double check to make sure the downpipe you get has the compatible 3 point flange and not a 2 bolt flange and double check to make sure its long enough to fit for the stock manifold and its not designed for a midlength header or anything like that.
Old Mar 6, 2011 | 07:36 PM
cobalt2010's Avatar
^^truth there. didnt think of that
Old Mar 6, 2011 | 07:41 PM
So I should probably just contact ZZP... ha
Old Mar 6, 2011 | 07:45 PM
yes. and what i said was under the assumption that you still are using the stock manifold
Old Mar 6, 2011 | 07:50 PM
Which I am
Old Mar 6, 2011 | 07:52 PM
ya then contact ZZP and see if it is compatible with a stock manifold
Old Mar 6, 2011 | 08:07 PM
Awesome, is there a rep on here for them? or no
Edit - nevermind, i found the rep and messaged him
Old Mar 14, 2011 | 05:03 PM
Update:
Got my ZZP Downpipe today, 2.5" piping, Magnaflow Cat, bolt up flanges... ZZP FTW! I'm going to order my Tsudo exhaust in the next few weeks and then ill get it all installed and post up some more pics/videos.
no_ss
Oct 18, 2015 11:58 PM
nathan112i
Sep 30, 2015 07:12 PM
09SSlow
Sep 28, 2015 12:37 AM
riceburner
Sep 27, 2015 11:10 PM
