2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Engine build!
Old Jun 11, 2013 | 10:28 PM
nhanson's Avatar
Engine build!
Well my motor finally gave way on a pull. She was knocking pretty good. I made it a whole 5 days on E85
I was loving this:
Started taking intake side off:
Got the head off, wasnt too bad:
Disassembled and found all my bearings were good...the rods not so much. #1 and #3 are the bad ones.
Sent head to LSJION for porting (heard great reviews and seen pictures of work). Also getting ZZP 82# valve springs in.
So basically standard engine build using wiseco pistons, eagle rods, ZZP valve springs, and ARP head studs.
Car was 2.8 pulley M62 on E85. Im going to drop to 2.7 on E85.
Then tax time next year TVS will be bought! (or if i come into some money somehow)
Old Jun 13, 2013 | 05:33 AM
Crav3's Avatar
This sounds bittersweet lol how much hp were you running?
Old Jun 13, 2013 | 10:33 AM
nhanson's Avatar
Had to of been 250ish whp. James said 270-290 chp.
Old Jun 13, 2013 | 02:50 PM
owlwyn's Avatar
so around the range where the lap start to give out. not bad.
I bet those were a fun 5 days tho.
Posted from Cobaltss.net App for Android
Old Jun 14, 2013 | 12:54 AM
nhanson's Avatar
Yea it was! Used to be doggy in humid/warm weather but E85 had no hiccup in any weather.
Old Jun 14, 2013 | 04:39 AM
Crav3's Avatar
Hmm now im thinking is I should upgrade my rods when I go turbo lol
Old Jun 14, 2013 | 06:10 PM
nhanson's Avatar
Im just glad it didnt break and blow a hole in the block
Old Jun 15, 2013 | 09:30 AM
TurboTechRacing's Avatar
Interested to see the build process happen, keep us updated
Old Jun 16, 2013 | 11:38 PM
nhanson's Avatar
Hope my 60s survive on ported head and 7500 redline
Old Jun 29, 2013 | 12:23 AM
nhanson's Avatar
Got some important parts today! If anyone is looking for a deal on internals (pistons, rods, and ARP head studs) let me know!
Old Jun 29, 2013 | 12:31 AM
noorj's Avatar
nice man! this thing will be a lot of fun. so you will be running stock sleeves?
Old Jun 29, 2013 | 12:48 AM
EXsoccer1921's Avatar
Might be a perfect time to test out some Mr b sleeves since you're going to want a proper piston to sleeve clearance anyways.
Old Jun 29, 2013 | 12:55 AM
nhanson's Avatar
Stock sleeves should be good (Gen2 block)
Im having a friend hone them out for me.
Old Jun 29, 2013 | 01:15 AM
SalvageBaltSS's Avatar
85% ethanol must be hard on your motor. still don't get why people tune there cars on e85?
Old Jun 30, 2013 | 01:22 AM
andrewcarr1993's Avatar
I've always wondered what the stock sleeves hold.
As for why people run E-85 it's because it can make a lot more power since it practically doesn't knock. On the down side you get much worse gas mileage and since you're making a significant amount of power over 93 octane pump gas it'll obviously be harder on the engine.
Old Jun 30, 2013 | 01:30 AM
alright thanks for explaining, lol in Washington I try getting no ethanol fuel and its like 5 bucks a gallon, but it always seems like my car runs better with it, so ill be putting non E before I head out to the track.
Old Jun 30, 2013 | 01:35 AM
When I was tuned I was told to just run 93 octane with ethanol (readily available) vs 91 octane no ethanol (only at NOCO stations). If I ever ran anything else it would skew the fuel table.
Old Jun 30, 2013 | 10:43 PM
nhanson's Avatar
i was getting 24* of timing with E85. Only 15* on 93 tune
Old Jul 1, 2013 | 02:17 PM
cobalt523's Avatar
im looking to build my engine, im researching what pistons and rods will work, and also a MAP sensor
Old Jul 7, 2013 | 09:19 PM
noorj's Avatar
are you going to be assembling everything? if so take lots of pics cuz I'm gonna be doing this at some point.
also any plans for balance shaft deletes or timing chain setup upgrades?
Old Jul 7, 2013 | 09:52 PM
BLAZIN07SS's Avatar
I'm too JDM for you
e85 is the elixir of the car gods it lets you get away with so much
Old Jul 8, 2013 | 12:35 PM
09cobalt 2.2's Avatar
are you taking the engine out of the car or no i wana put rods and pistons in mine but dont wana take it to the machine shop to balance it will i be ok with that
Old Jul 9, 2013 | 12:01 AM
cobalt523's Avatar
Wiseco and eagle sell a package deal for rods and pistons
Old Jul 9, 2013 | 10:41 AM
nhanson's Avatar
Wiseco and eagle rods with ARP head studs is the combo you want.
Yea me and some friends (another guy that has a built L61)
That stuff will remain stock. I might take her to 7500 on the first gear shift (auto) then probably 7200 for the 2nd shift and 7000 for the 3rd.
I left my block in the car and had a buddy who had the hone spindle do it for me. Just make sure to clean it good after.
I can get you $925 for the 3 items I listed above. Just PM me.
Old Jul 9, 2013 | 01:43 PM
noorj's Avatar
You got some ***** if you actually end up reving to 7500 in first. I would say if anything put your limiter lower in 1st than the others because the revs are climbing so fast the cutoff won't be able to slow the engine down til it reaches like 7550-7600
