2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Engine build!
Old Jul 9, 2013 | 01:49 PM
nhanson's Avatar
Yea youre right on that. Probably just have cutoff at 7500 and then shift at 7200 or maybe a tad higher.
Old Jul 10, 2013 | 06:06 PM
09TcSedan's Avatar
subd!
Old Jul 19, 2013 | 12:08 PM
noorj's Avatar
any updates?
Old Jul 19, 2013 | 12:36 PM
andrewcarr1993's Avatar
Also interested. I've been trying to follow this build, want to know how much the stock sleeves hold also.
Old Jul 21, 2013 | 05:26 PM
nhanson's Avatar
Finally getting rod bearings tomorrow...dealer was slow on getting them in.
My head came back and looks AWESOME.
If you guys need porting LSJION (Josh) is your guy.
Old Jul 21, 2013 | 05:29 PM
nhanson's Avatar
Exhaust side...intake wasnt touched.
Old Jul 22, 2013 | 01:11 AM
cobalt523's Avatar
Don't know if I should build my auto trans or my engine first... Only have money for one
Old Jul 23, 2013 | 12:00 AM
I thought it already had a ZZP auto trans? If it doesn't then you'll want that first because if you build your motor your trans is going to leave you stranded vs building trans which just helps its reliability.
Old Jul 28, 2013 | 09:49 PM
nhanson's Avatar
Well had all 4 pistons in and then forgot about the spiral locks for the wrist pins. Went to reinstall and broke a ring on a piston, it got pinched from the shitty compressor i was using.
So 3 are in and torqued and getting a new ring set tuesday.
Old Jul 30, 2013 | 08:02 AM
noorj's Avatar
that's shitty but think of it this way, it's better to have problems now than down the road.
Old Jul 30, 2013 | 03:13 PM
  #36
nhanson's Avatar
Yea im glad I caught it because the piston did go in but i saw a small piece by the top so I pulled it out. No cylinder wall damage
Old Jul 30, 2013 | 03:45 PM
  #37
574's Avatar
574
Any more pictures?
Old Jul 30, 2013 | 03:46 PM
  #38
nhanson's Avatar
Well i can get a picture with 3 pistons in...lol
Old Jul 30, 2013 | 03:47 PM
  #39
574's Avatar
574
Get your new rings yet?
Old Jul 30, 2013 | 03:48 PM
  #40
nhanson's Avatar
Tomorrow they come
Old Jul 30, 2013 | 03:50 PM
  #41
574's Avatar
574
**** you'll probably be running before I am
Old Jul 30, 2013 | 03:51 PM
  #42
nhanson's Avatar
This week!
Old Jul 31, 2013 | 01:06 PM
  #43
noorj's Avatar
did you do all new gm main and rod bearings?
what'd you gap your piston rings to?
is that deal you got only on 2.2 rods/pistons or can a 2.4 get some lovin too?
Old Jul 31, 2013 | 01:09 PM
  #44
nhanson's Avatar
Block wasnt taken out and crank stayed in. Original main bearings but new GM rod bearings.
Old Jul 31, 2013 | 01:26 PM
  #45
noorj's Avatar
gotcha, ring gap?
Old Jul 31, 2013 | 04:57 PM
  #46
nhanson's Avatar
Originally Posted by noorjariri
gotcha, ring gap?
Followed what wiseco said...they were within the spec. Ill look at what they were.
Give me some part numbers and ill run them by him to see what deal he can get. Pistons, rods, ARP studs?
Old Aug 2, 2013 | 07:59 PM
  #47
nhanson's Avatar
Well I effed a head bolt so now im waiting on that. It didnt thread all the way and the nut screwed on the unthreaded part and lost its threading.
But the engine is timed, head is on, intake manifold on, and im finishing up the heat exchanger stuff and putting the bumper on.
Old Aug 2, 2013 | 08:28 PM
  #48
574's Avatar
574
Hell yeah. Overnight that ****
Old Aug 2, 2013 | 10:52 PM
  #49
nhanson's Avatar
Im not a baller
I have a friends spare car so its not too bad
Old Aug 4, 2013 | 08:44 AM
  #50
noorj's Avatar
looks good man! how was timing it with the vvt actuators? I've done a couple motors (not ecos) but never anything with vvt
