2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
engine code P0011
Old May 24, 2013 | 07:57 AM
owlwyn's Avatar
engine code P0011
P0011: camshaft position- timing over. advanced or system performance (bank 1)
I have no clue what this means, aside from the fact, its not active right now and my car still runs like crap at times. and I can't have it go through the shop till the light comes back on since it'll be warranty.
and what I mean by running like crap is that it idles rough, gets jerky when I'm just cruising at times, and sounds like it has a cam.
Posted from Cobaltss.net App for Android
Old May 24, 2013 | 09:10 AM
Sox-Fan's Avatar
Got Brakes?
Cam actuator. It's 25 bucks at rock auto. Takes all of 36 seconds to change with a 10mm socket and an extension. It's right on top of the motor next to the spark plugs. Do it yourself. Give me a second, I can even get you the part number.
Old May 24, 2013 | 09:13 AM
Sox-Fan's Avatar
Got Brakes?
Actually, I can't give you the part number... Mine's an LNF.
Old May 24, 2013 | 09:18 AM
Sox-Fan's Avatar
Got Brakes?
https://www.cobaltss.net/forums/prob...-p0017-190917/
Anyway, slight chance of debris on the screen, but probably just needs to be changed. Easy job.
Old May 24, 2013 | 10:38 AM
owlwyn's Avatar
is there one or 2 of them?
I had it/one replaced not even a year ago.
Old May 24, 2013 | 10:39 AM
owlwyn's Avatar
and thanks.
I kinda figured it was that again, but the fact it was running bad made me worried that it was something worse.
Old May 24, 2013 | 10:43 AM
Sox-Fan's Avatar
Got Brakes?
On the LNF there is an intake and an exhaust. I'ds assume two for yours as well, but never having even looked at one, that's just an assumption. And 11 code is the intake side if I remember right.
Old May 24, 2013 | 10:45 AM
LS6Rally's Avatar
thres two: exhaust and intake
same head as the LE5
Old May 24, 2013 | 06:13 PM
owlwyn's Avatar
do you know which is which?
Old May 25, 2013 | 11:35 AM
owlwyn's Avatar
2 new codes..
B2AAA
B2A00
Both undefined
turbochargedss2012
Sep 20, 2023 12:17 PM
ernnyyes
Oct 2, 2015 05:16 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
DocSvensk
Sep 27, 2015 02:24 PM
