fuel psi!
You could put smaller fuel line on car and get higher psi. All that means you will blow the car up. You know psi doesn't always help if you could flow more fuel thru the rail. Get you a bigger fuel pump if you really don't want to do anything.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
and i have looked into the regulator but is there any way without mods i could raise the psi?
