2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Gear oil fill????HELP
Old Feb 5, 2012 | 01:48 PM
unijabnx2000's Avatar
Who has a picture of where the gear oil fill on the manual transmission is at?
2.2LAP
I just spotted that my pass side axle seal is leaking.....
help.
Old Feb 5, 2012 | 02:06 PM
cleanxfe's Avatar
sorry no pic but should be on same side as drain plug on tranny to the right of axle looks the same as drian plug
Old Feb 5, 2012 | 03:10 PM
09xfebalt's Avatar
You are aware it takes ATF and not gear oil correct?
Old Feb 5, 2012 | 03:38 PM
Mindrot's Avatar
^, 4T45e fill cap is located underneath the fuse box kind of. You'll need to do some digging around with the harness in the way. Should be simple to find.
Old Feb 5, 2012 | 03:41 PM
found it, its the same spot as the LSJ trans....
gotta find a seal now...
and why would it take ATF? the A in ATF stands for automatic... all other 5 speeds ive owned have been gear oil
Old Feb 5, 2012 | 03:45 PM
Mindrot's Avatar
I'm pretty sure its suppose to be ATF fluid. Dexron 6 (however you spell it)
Old Feb 5, 2012 | 10:05 PM
09xfebalt's Avatar
Dex 6 is what it takes. SS models take special fluid base models take ATF
Old Feb 5, 2012 | 10:10 PM
royce777's Avatar
- Redline MT-90 Manual Trans Fluid #02-02-00968
this is what im going to be running
Sl0wbaltSS
Nov 21, 2018 11:11 PM
RaginChopsuey
Oct 27, 2015 01:27 PM
biniecki
Oct 25, 2015 02:23 PM
Trav3480
Oct 1, 2015 08:17 PM
DocSvensk
Sep 27, 2015 02:24 PM
