2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
installing boost gauge
Old Mar 11, 2010 | 10:00 AM
09blackonblack's Avatar
where can i get a vacuum source to hook up my boost gauge? i know its major rice to have a boost gauge and no f/i... but i have the turbo kit i just need to install it.
the brake booster is too big and the evap is hard plastic... unless i change it from plastic to rubber, i see no way to install it shy of buying an $8 fitting and tapping the manifold.
Old Mar 11, 2010 | 10:42 AM
iboost's Avatar
I replaced my factory boost gauge with AEM's digital one. I taped here and I have boost and vacuum now...
Old Mar 11, 2010 | 11:11 AM
i wish it was that easy... im not direct injection so i cant use that method.
Old Mar 11, 2010 | 11:14 AM
iboost's Avatar
oh yea derr...lol. My bad...good luck
Old Mar 11, 2010 | 11:19 AM
1badBlueberrySC's Avatar
You won't be able too.... why don't you just wait till you have your setup on before you install a gauge that does nothing for you right now
Old Mar 11, 2010 | 01:06 PM
bc i want to go ahead and get it done so its ready when i put my turbo on
Old Mar 13, 2010 | 08:29 PM
cobalt523's Avatar
im putting a boost gauge in my car now, there should be a small port on the manifold that has a rubber boot on it, hook the gauge to that, im putting on the boost gauge now then waiting for you to finish your build thread to ad the turbo
Old Mar 15, 2010 | 12:49 AM
the l61 manifold has the nipple. im a lap so i dont have one
Old Mar 15, 2010 | 01:03 AM
cobalt523's Avatar
how did the boost gauge turn out?
oh crap! i got LAP too, on the driver side of the manifold there is tubing comming out of it, is therea way to use that?
it lights up but thats it... i had to go out of state for a wedding before i could finish it.
Old Mar 15, 2010 | 01:12 AM
cobalt523's Avatar
yeah i got LAP too, i didnt install the gauge yet but there is tubing that runs off the intake mani on the driver side.....can we use that to hook it up?
Old Mar 15, 2010 | 01:32 AM
i would have to see a pic, but either line will work. just the evap line is plastic and hard to do it with. and you say your manifold has a vacuum nipple?
Old Mar 15, 2010 | 01:52 AM
cobalt523's Avatar
i dont have the nipple, my friend said that he hooked his up witht the nipple but i think he has a L61, so if i cut part of the hard plastic evap line, put in a rubber tubing, then put a vacume T between it, i can install the boost gauge?
Old Mar 15, 2010 | 01:58 AM
reaper89's Avatar
thats what i did to hook my vacuum gauge up. cut the the line, put the T in there, then ran the tube to the gauge. and its worked for almost a year and half with no problems
Old Mar 15, 2010 | 02:02 AM
cobalt523's Avatar
what does that evap line do?
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Jan 12, 2016 12:01 AM
justinchinn
Oct 2, 2015 12:18 PM
Sep 27, 2015 08:53 PM
