2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
LT exhuast removal? help
Old May 17, 2012 | 05:04 PM
Mr.09cobalt's Avatar
last time i changed my exhaust on a car lift is it possible to remove the exhuast with just advanced auto car jacks? is that high enough the slip the exhuast out i i have the lt2 09 and theres no flanges til the dp
Old May 17, 2012 | 05:07 PM
zerosk8ter83's Avatar
just grind it off,less hassle
Old May 17, 2012 | 05:18 PM
K-Train04RL's Avatar
the only way to slip it out is to drop the rear end and most likely unbolt the whole twisting beam. i normally just cut it off. done a bunch now and have never succesfully slipped one out without taking off the beam, which means bleeding brakes .... ugh.
Old May 17, 2012 | 05:33 PM
some said u can slip it over just enough room but last time i tried to do it i couldnt figure it out im not cutting the exhuast
Old May 18, 2012 | 10:38 AM
bump is it do able with it on a car lift
Old May 21, 2012 | 11:39 AM
Old May 27, 2012 | 11:50 AM
noorj's Avatar
Yes, if you cut the cat-back at the rear beam you can do it on jack stands/lift.
Old May 27, 2012 | 12:01 PM
TommyP's Avatar
AWD > FWD
the rear axle does not droop far enough down to slip the exhaust out, doesn't matter if it's on stands or a lift.
Old May 27, 2012 | 12:12 PM
05Slowline's Avatar
before the over axle
Old May 27, 2012 | 12:30 PM
nhanson's Avatar
Gotta cut it
brickloaf
Show & Shine
56
Jun 18, 2019 12:51 PM
jmelton327
Sep 25, 2015 09:44 AM
Extreme Dimensions
Sep 24, 2015 05:24 PM
katahdin_lubricants
Sep 20, 2015 07:24 PM
Getaway_Driver
Sep 8, 2015 09:41 AM
