2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Thoughts on 2.7 pulley
Old May 27, 2012 | 04:41 PM
nhanson's Avatar
Right now I have 2.9 and get 13 lbs (also ported blower). Will it hold up?
I want more power!
Check sig for current mods
Old May 27, 2012 | 04:43 PM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
On 60s.. yes.
13lbs on a 2.9 seems low though, doesn't it?
Last edited by tylerjclance; May 27, 2012 at 04:43 PM. Reason: Automerged Doublepost
Old May 27, 2012 | 04:45 PM
nhanson's Avatar
2.2s generate less because of smaller crank pulley
Old May 27, 2012 | 06:56 PM
Validater's Avatar
What about internals? Are you gonna keep them or change them? If you change them then yes do it.
Old May 27, 2012 | 10:28 PM
nhanson's Avatar
Not at this point. Sometime in the future ill buy a spare engine and build that.
Old May 27, 2012 | 11:09 PM
bluebalt07's Avatar
I wouldn't go to a 2.7 on stock internals. That's just asking for trouble
Old May 27, 2012 | 11:21 PM
nhanson's Avatar
2.2s make less boost due to crank pulley. Im thinking it might be ok.
Old May 27, 2012 | 11:24 PM
GSDIESEL300's Avatar
The 2.2 internals aren't as strong as Lsj. I wouldn't recommend it. I was going to go with a 2.8 but I settled for the 2.9 and a hold 15 psi boost and am happy with it.
Old May 27, 2012 | 11:26 PM
nhanson's Avatar
im only at 13 with 2.9 and ported blower.
Old May 27, 2012 | 11:40 PM
bluebalt07's Avatar
I think the lowest anyone has gone on stock internals was a 2.8. I think stenguyen went down that low and he blew his up
Old May 27, 2012 | 11:46 PM
nhanson's Avatar
But he was on E85 i think im sticking with 93 for now
Old May 27, 2012 | 11:51 PM
nhanson's Avatar
ah **** he was on a 2.9...not sure what type of gas though
Old May 28, 2012 | 12:07 AM
I'm ported too.
Old May 28, 2012 | 01:17 AM
bluebalt07's Avatar
Also 2.2s make less boost primarily because of the larger displacement than the LSJ. Also why 2.4s makes even less still. Not useful to whether a 2.7 is safe or not but for future reference
Old May 28, 2012 | 01:32 AM
Pick up water/meth and go for it
Old May 28, 2012 | 01:35 AM
killtank's Avatar
Bump for future 2.7 upgrade
Old May 28, 2012 | 01:51 AM
1LowLS's Avatar
06blackbalt went 2.7 on his stock 2.2.he blew up 3 motors on it.Wait till you build it otherwise you asking for a popped rod or ringland.
2.9 @ 13 psi here.well was anyways lol.
Old May 28, 2012 | 08:15 AM
hhrfreek's Avatar
^ LOL.
Honestly...I understand how 2.9 is the edge of wrecking a motor because going from the 2.9 to the 2.7 pulls wayyy better. Its fun but just watch your iat2s. I am running a 2.7 on my 2.4l and only seeing 11-12psi. I have a ported head and full exhaust though. The 2.7 really does need meth. Especially now that its hot outside. I still have it on but i am running e85. if its ~70 degrees ambient my iat2s are ~100(w/dualpass/s3 he, phenolic spacer) and if I do a 3rd gear pull to 7600rpms I will see 145 degree iat2s. So that means no back to back pulls and if you run up the gears (1,2,3rd) youll see temps over 160. Maybe less though if you are revving lower. Takes a while for temps to recover too. The 2.9 recovers faster and operates ~10 degrees cooler.
Old May 28, 2012 | 10:06 AM
nhanson's Avatar
I usually run 23* above ambient. That's with out phenolic but that's with the cx racing pump. I'm going to think a bit more. Just bought the Bosch pump so hopefully that helps
Old May 28, 2012 | 06:58 PM
IonNinja's Avatar
I'll be going to a 2.7 once I build the bottom end...should be fun.
I don't beat on my car in the summer anyway, too hot for that
Old May 28, 2012 | 08:14 PM
huckernage's Avatar
OFF TOPIC sorry
nijan what about losing your NHL team.
we want them in qc city
AT 1:09 you guy can see peter and anton stastny and the coach michel bergeron
even it is in french, you ll understand that we love hockey
Nordiques nation radiox montage - YouTube
Old May 28, 2012 | 08:21 PM
05Slowline's Avatar
cruising temps don't matter......in4blowup.
Old May 29, 2012 | 07:01 PM
nhanson's Avatar
I decided on 2.8. Need to do suspension next. Just bought the bosch pump too.
Im sure this car will eventually blow up...just not right now
I WANT MORE!
biniecki
Oct 25, 2015 02:23 PM
Oct 20, 2015 09:56 PM
SSLOW06
Oct 1, 2015 07:21 PM
patooyee
Oct 1, 2015 01:07 PM
ChrisTutoki
Sep 24, 2015 08:39 PM
