2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Bigger injectors
Old May 29, 2012 | 07:33 PM
hi106's Avatar
Bigger injectors
So I bought 42 injectors for my balt for the supercharger I was planning on putting in it. It's a 2.2 09 LS. I have since decided not to supercharge it currently and was wondering if I can still use the 42 injectors in it. If I can what all is required to run them and will they help on power/fuel economy or just be pointless?
Old May 29, 2012 | 11:45 PM
bluebalt07's Avatar
You will need a different harness to plug them in first off and then a tune to run them. And after all that they will not help with power or fuel economy at all. The only need for more fuel is more air flow (i.e. forced induction)
Old May 30, 2012 | 01:53 AM
Ceej's Avatar
How would it do absolutely nothing...
Old May 30, 2012 | 10:47 AM
bluebalt07's Avatar
Like I said the only reason to need bigger injectors is if you are flowing more air into the engine. Unless you go forced induction or do major head work (porting, cams, etc) you will not max out the stock injectors. Just putting bigger injectors with the potential to inject more fuel will not do anything at all for performance.
Old May 30, 2012 | 10:50 AM
07LSJ's Avatar
well if you DO decide to put them on i have an injector harness for sale that i think will fit.
Old May 30, 2012 | 05:19 PM
nhanson's Avatar
Absolutely pointless...unless you ran E85
Old May 31, 2012 | 02:49 AM
hi106's Avatar
I have the harness for them, I just was wondering if they would do anything.
Old May 31, 2012 | 08:03 AM
hhrfreek's Avatar
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
