2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
M62 Install on 2.2LAP (XFE Remix)
Old May 17, 2010 | 06:11 AM
Cobaltxfe09's Avatar
Cool M62 Install on 2.2LAP (XFE Remix)
Aight guys...the time has come. Thanks to Jared for helping me jump start my build, I will be doing the M62 build on my 2.2LAP. Im planning for a late winter/early spring 2011 build.
Alot of updates will not come for a few months. I have a wedding to pay for first and then after that I will be purchasing all the big stuff. But for now, I wanted to start this thread to be able to post info and pictures.
Just like with Jareds build, we will be streaming it live here >>> Foximus Motorsports.
I am using Gene Culleys list for the essentials, but it is modified for my build. I will post the list along with the additional info and parts I will be getting. Once I have aquired a certain part I will edit this post.
Parts Needed - (Black)
Parts Acquired -(Red)
Most of the new GM parts (bolts/gaskets will be purchased thru OEHQ.com)
New GM Parts
12584333 - LSJ Endplate Air bypass valve (O-ring)
12575463 - LSJ TB Gasket
11900248 - LSJ TB To SC Bolts (4)
12584342 - LSJ Supercharger Gasket
12594387 - LSJ IC Pump Insulator
89046833 - IC Pump Connector
12597855 - LSJ Intake Manifold Gasket
12597993 - LSJ Stage 2 Serpentine Belt
15247280 - LSJ Upper Radiator Hose
15253932 - LSJ Power Brake Booster Vacuum Hose
12584369 - LSJ TB To Purge Solenoid Tube
12585150 - LSJ IC Pump Rear Bracket To Intake Manifold Mount
12586367 - LSJ IC Pump Front Bracket To Rear Bracket
12586632 - LSJ Lower Intake Manifold Mount
11516342 - LSJ Intake Manifold Mount To Block Bolts (2)
11589214 - LSJ Supercharger to Intake Manifold Bolts (4)
******* - LE5 8 Pin TB Connector
15231157 – LSJ Downpipe To Cat Back Gasket
15235773 – LSJ Exhaust Manifold To Downpipe Gasket
22729469 – LSJ Windshield Washer Container
22732432 – LSJ Wiper Cowl To Washer Container Hose
New Non - GM Parts and misc
ZZP S3 Heat Exchanger
Vacuum | Boost Gauge
AEM Wideband Air | Fuel Ratio Gauge
Aeroforce Interceptor Gauge
Intense Racing 2.8 pulley/hub
Bosch I/C pump (OTTP)
NGK Copper Spark Plugs (Part# LFR6A-11) (Also one step colder)
RD Fabs LSJ CIA (OTTP)
Siemens 60 LB injectors with Harness (OTTP)
Option B Setup (OTTP) or used
Pulley Boys Tensioner Relief tool
Spec Stage 2 Clutch
Used Parts
Eaton M62 Supercharger
Stock LSJ Tensioner
Stock LSJ Idler Pulley
Stock LSJ Throttle Body
Stock LSJ Intake Manifold
Stock LSJ Alternator Bracket
ZZP Triple Pillar Pod
Stock LSJ Downpipe
Stock LSJ Exhaust Manifold
LSJ Dipstick tube
Supercharger Cooling System
22697069 – LSC SC Coolant Reservoir
15076936 – LSJ SC Coolant Reservoir Cap
15271970 – LSJ SC Coolant Reservoir Bracket
22697111 – LSJ SC Coolant Reservoir Overflow Hose
22699879 – LSJ SC Coolant Reservoir Inlet To Top Intake Manifold End Plate Hose
22707607 – LSJ Bottom Intake Manifold End Plate To Intercooler Pump Outlet Hose
Standard Bolts Needed (Not GM)
MAP To Intake Manifold
M6 x 1.0 x 25 (Qty 1)
LSJ Intake Manifold Mount Bracket To Intake Manifold
M10 X 1.50 x 50 (Qty 1)
LSJ Rear IC Pump Bracket To Intake Manifold Mount
M8 X 1.25 X 25 – (Qty 2)
LSJ Front IC Pump Bracket To Rear IC Pump Bracket
M8 X 1.25 X 35 – (Qty 2)
LSJ Idler Pulley To Alternator Bracket
M8 x 1.25 x 25
LSJ Intake Manifold To Block
M6 x 1.0 X 75 (Qty 2)
M6 x 1.0 x 25 (Qty 5)
LSJ Alternator Bracket To Block
M8 X 1.25 X 130 (Qty 3)
LSJ SC Bypass Valve To SC
M8 X 1.25 X 20 (Qty 2)
LSJ Tensioner Lower To Alternator Bracket
M8 x 1.25 x 35
LSJ Tensioner Upper To Alternator Bracket
M8 X 1.25 x 40… not standard bolt though. Has to be metric hex socket bolt.
LSJ SC Reservoir Bracket To SC
M6 x 1.0 x 15 (Qty 2)
LSJ SC Reservoir To SC Reservoir Bracket
And of course the tune.
If anyone has any info or input please do not hesitate to post up.
Also, if you have any parts that are on this list that I still need, please shoot me a PM and let me know what you have and what you would like for the part. Im kinda broke right now because Im not working but that should be changing this week.
Thanks guys!
Old May 17, 2010 | 06:38 AM
Black SS/SC 06's Avatar
There are a lot of those in black...............
Old May 17, 2010 | 06:44 AM
I know
O well...I have plans...all the small stuff will come up fast. I am in no rush...you gotta understand that too.
I'd rather take my time, make sure I have everything and be well prepared.
Old May 17, 2010 | 02:17 PM
Well good luck, sounds like you have some work to do.
Old May 17, 2010 | 02:23 PM
conerboner's Avatar
sub'd
Old May 17, 2010 | 02:25 PM
Nighthawk243's Avatar
Good luck with the build.
Old May 17, 2010 | 05:59 PM
Thanks guys!
Old May 17, 2010 | 06:06 PM
thebucky84's Avatar
good luck man! and just take ur time so it comes out right the first time! lol
Old May 17, 2010 | 06:26 PM
I'm going down to Lowes tomorrow to get the odd ball bolts.
Old May 18, 2010 | 05:46 AM
Hey guys, can I get some recommendations on gauges.
Old May 18, 2010 | 07:01 AM
Aeroforce Interceptor. Not sure if they have one that works with your model. Ask one of the vendors that sell them.
Old May 18, 2010 | 10:46 AM
07Maliboo's Avatar
Good luck on your build buddy, I'm doin the same thing. So far I've only got the exhaust system. I haven't found anything out about the interceptor either yet.
Old May 18, 2010 | 05:13 PM
Thanks guys ^^
Picked up most of the misc bolts today. Home Depot didn't have the others and neither did Lowes.
Old May 19, 2010 | 08:10 PM
Question
OK, Stupid question time!
I was at the junkyard today and spotted a few 2.4's with the 8pin throttle body harness.
Can I use that for rewiring the TB? Or do I have to use the LSJ TB harness?
Thanks guys.
Old May 20, 2010 | 07:00 AM
anyone?
Old May 20, 2010 | 08:32 PM
Gene Culley's Avatar
Talking
I bought the LSJ TB connector and then spliced it properly. Like everyone said, take your time. Mine probably took 2 weeks of messing around with it, but I'm very picky, etc.
Old May 20, 2010 | 09:03 PM
Thanks Gene, but I have found out it will work and I just have to repin it. That will not be a problem.
Gene, what is the size of that hex plug you used to plug the blower?
Nevermind...i found it in your thread.
7/16 tap (without drilling) and installed a 7/16 allen hex socket plug
Last edited by Cobaltxfe09; May 20, 2010 at 09:03 PM. Reason: Automerged Doublepost
Old May 23, 2010 | 02:29 AM
Next stupid question.
Will the LSJ dipstick tube work on the 2.2?
The reason I ask is because I noticed on Jareds car it's kind of a tight squeeze to get to the dipstick. I would love to use the LSJ dipstick tube if it will work.
Thanks guys!
Old May 23, 2010 | 01:34 PM
Bump?
Old May 23, 2010 | 10:02 PM
MP81's Avatar
I used my stock dipstick tube.. Was able to move it out of the way...
Old May 23, 2010 | 10:05 PM
YA, but when we did Jareds car I noticed that it was not budging for ****. Ya know what I mean...
Old May 23, 2010 | 11:30 PM
Pedobear's Avatar
i thought IIRC that hunterkiller broke his off into his oil pan and consequently considered using the LSJ dipstick, i dont remember reading that he actually installed it
Old May 24, 2010 | 12:07 AM
MP81's Avatar
Oh...it'll budge - I made mine budge, haha. I was just careful.
Old May 24, 2010 | 07:10 PM
Thanks, Im gonna check out his thread again.
Thanks Kyle!
Old May 24, 2010 | 08:15 PM
MP81's Avatar
No problem Mike
