2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
my build thread
Old 04-21-2010, 02:21 PM
  #101
elecblue06's Avatar
Originally Posted by 07SuperchargedSS
Do you have to drill and tap the oil pan or is there already a spot to dump the return oil from the turbo?
also will the LNF intercooler pipe kit fit on the 2.2
if you get a maf relocation hot side that will work but the cold side wont
you can also do a regular hot side then get an LNF intake
Old 04-21-2010, 02:40 PM
  #102
cobalt523's Avatar
drill and tap, zzp sells the fitting too
Old 04-21-2010, 02:45 PM
  #103
09blackonblack's Avatar
yep you have to drill the pan. and yeah you can use the hotside stock or not... cold side you cant. unless you use the ss/tc intake manifold.. which idk if you can use it or not.
Old 04-21-2010, 05:49 PM
  #104
07SuperchargedSS's Avatar
Well that just sucks ass....maybe Ill just rig the oil fill cap to be the drain like with the STS kit...
Old 04-22-2010, 02:02 PM
  #105
You get pictures of this kit installed yet?!?!
Old 04-22-2010, 03:22 PM
  #106
the pics are posted already in here and a couple other of my threads
Old 04-23-2010, 12:20 AM
  #107
cobalt523's Avatar
i talked to matt from zzp and he said that he could drill and tap a lsj oil pan with a oil return fitting for a charge, use the lsj oil pan because it hold more oil which is better for the turbo! and 09black u seem to know alot of **** bout cobalts so can u comment on my b&m thread? thanks
Old 04-23-2010, 07:22 AM
  #108
well you hit the nail on the head... i SEEM... but idk **** lol
Old 04-23-2010, 01:44 PM
  #109
cobalt523's Avatar
well u convinced me
Old 04-23-2010, 05:37 PM
  #110
hows the car take to 12psi of boost?
Old 04-23-2010, 08:27 PM
  #111
Eco-Mod's Avatar
Good to see that turbo I had laying around went to good use! Now you need a clutch and we need pics and numbers!!!
Old 04-23-2010, 10:00 PM
  #112
haha ya the dyno is too expensive here lol almost 200$ for 3 pulls
Old 04-25-2010, 01:10 PM
  #113
Gene Culley's Avatar
Talking
Originally Posted by 09blackonblack
its not how much boost... its how much horsepower... with that said how much are you putting down gene?
He asked how much boost they could handle, so I was just answering the question as asked. I don't know how much I'm putting down because my clutch won't go. LOL. I am installing SPEC stage 2+ this week and once I get that done and my tune redone I will take to dyno.
Old 04-25-2010, 11:21 PM
  #114
yeah i knew you were having clutch troubles but im trying to get an idea on how much power our lap can handle
Old 04-27-2010, 05:22 PM
  #115
Any updates on how much boost its liking???
Also I was looking today and I'm going to have to relocate my maf...did you as well? Is there a plug and play kit?
Last edited by 07SuperchargedSS; 04-27-2010 at 05:22 PM. Reason: Automerged Doublepost
Old 04-27-2010, 08:15 PM
  #116
i didnt have to relocate it the way i went about doing it. the BEST way is to use a zzp maf housing.
Old 04-28-2010, 02:10 PM
  #117
Ok, the way my kit was designed is for the lsj. Therefore the maf housing is on the driver side. Dont I have to relocate it from the passanger side hot pipes to the driver side cold pipes????
Old 04-28-2010, 08:00 PM
  #118
yeah just so your maf can read the cooler air temps after it passes through your fmic.
Old 04-29-2010, 08:27 AM
  #119
that's what I thought, thanks man! Also, how's your car taken to 12 psi?
Old 04-29-2010, 08:33 AM
  #120
havent got there yet im still on 9 slowly working my way up letting the turbo break in lol
Old 05-05-2010, 01:28 PM
  #121
ebristol's Avatar
When is this beast hitting the rollers?
Old 05-05-2010, 06:49 PM
  #122
^^^when i can afford the $200 for 3 pulls and get a new mbc.
Old 05-07-2010, 02:07 PM
  #123
Hows your car doing? Any problems with it?
Old 05-07-2010, 03:02 PM
  #124
runs pretty good... i think my clutch is starting to hate me and the turbo here is a 60-100 pull
Old 05-07-2010, 03:11 PM
  #125
elecblue06's Avatar
looks slow :P
Quick Reply: my build thread
