2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
need help!!!
Old Feb 16, 2011 | 01:17 AM
BlueBalt1113's Avatar
need help!!!
so i am looking into going stage 2 comp cams with my 07 ls this spring but im not sure of what all to get to make this happen to where i wont destroy my motor someone or everyone please help!!!
Old Feb 16, 2011 | 01:34 AM
redcobalt07's Avatar
They will not fit into your car. First off a 2007 is an L61 not a LAP. Second, the 2007+ years cannot take the aftermarket comp cams. They do not fit.
Old Feb 16, 2011 | 02:52 PM
um first off the 07 is a lap engine just saying so what should i do to get a power boost cause i want power lol
Old Feb 16, 2011 | 02:54 PM
i swore on it being a lap cause it does not look like the l61 with the coil pack on top from what ive seen
Old Feb 16, 2011 | 06:37 PM
jbenso4's Avatar
coil pack has nothing to do with it...2009+ are LAP, you have an L61, but anyways i had Comp stage 2 cams in my 2007. All it requires is a tune from trifecta
Old Feb 16, 2011 | 06:50 PM
C_A_D88's Avatar
yea man mines an 07 it a l61 laps are 09 n up
Old Feb 16, 2011 | 07:58 PM
how did you get the cams to fit into your 2007?
Old Feb 17, 2011 | 11:44 AM
jbenso4's Avatar
they were made for it. only difference is when i had them, i needed to get the cam positioning sensor pressed on. Now Vince has the capability to tune it so that is not necessary. Just make sure if you do it you get the springs and retainers too.
Old Feb 17, 2011 | 03:17 PM
how much did it cost for you to do this and what was the power gain???
Old Feb 17, 2011 | 03:21 PM
Still think you have a LAP?
Old Feb 17, 2011 | 03:23 PM
idk cause i look at pics of the l61 and to me it looks different but i guess it is
Old Feb 17, 2011 | 03:28 PM
well the 2005 2006 L61's look different from the 2007 2008 L61's
Old Feb 17, 2011 | 03:31 PM
reaper89's Avatar
only because of how the coil packs are set up. 05-07 have a single pack for all 4 plugs, where as 07+ has 1 for each plug
Old Feb 17, 2011 | 05:33 PM
O ok but back to the cams
Old Feb 17, 2011 | 06:34 PM
You aren't going to find a set of cams from any company. Your best best is getting a set custom grinded from a machine shop.
