2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Possible to reach 200HP with no Turbo/SC?
Old May 30, 2010 | 08:45 PM
ashbyLT09's Avatar
Just trying to see if it is possible. and also do they make Chips for our ECUs that are reliable?
Old May 30, 2010 | 08:50 PM
TommyP's Avatar
AWD > FWD
Possible? Yes. It's gonna take a lot of money and work though. By chip, do you mean those ebay chips? Cuz those are junk. Trifecta tune is what you want.
Old May 30, 2010 | 08:51 PM
gwatson650's Avatar
you would probably need to get nitrous oxide d00d!
Old May 30, 2010 | 09:25 PM
Blown07SS's Avatar
Yea do internals nitrous and a tune and should be close. At first I thought you ment cobalts in general lol
Old May 30, 2010 | 09:28 PM
DarkCobalt13's Avatar
Easiest way is with NO2 but its possible to build the motor to 200+. Your gonna spend alot more money for a lot less power if you wanna go N/A
Old May 31, 2010 | 01:16 AM
Nighthawk243's Avatar
50 shot of Nitrous with some bolt ons.
As far as all motor, you'd easily spend about 4 times as much as you would have by going FI. All motor works pretty well on large displacement V8's, but it sucks for small displacement 4 bangers. The highest powered N/A GM 4 cyl I've seen was the W41 Quad 4, but you had to rev the **** out of it because of the way the cams were.
Old May 31, 2010 | 12:00 PM
ashbyLT09's Avatar
dang, okay. i just wanted to see if there were a way before i start saving to put a supercharger in my 2.2. and as far as the chip goes, i saw those ebay ones, garbage i know lol. ill do some research on that tuning place u mentioned.
Old Jun 7, 2010 | 06:40 PM
SS Flash's Avatar
Boost it!!!! **** N02
Old Jun 7, 2010 | 06:43 PM
blk06cbltss's Avatar
a guy up here in wa has a built 2.2 and im sure its 200+ if not very very close and id say dont go that route its not worth it. youre better off just getting a sc or tc
Old Jun 7, 2010 | 07:00 PM
Dart_SI's Avatar
put a honda motor in there. only way really.
Old Jun 7, 2010 | 07:06 PM
aweSOMeBalt's Avatar
Just
Boost
It
Old Jun 8, 2010 | 11:44 AM
SS Flash's Avatar
Dude did u really put a k20 in ur Balt!??
Old Jun 15, 2010 | 10:17 AM
Blue_Balt's Avatar
Doing it N/A is really expensive, especially for the power you get. Better off going FI like others have said.
Old Jun 23, 2010 | 12:50 PM
Zero6LS's Avatar
take it from someone who went the N/A route, its a waste of time. u can get good gains with bolt ons but the cars never gonna be hot **** fast. depends what the purpose of ur build is tho too. thats a big thing to consider, wether boosting or going N/A.
Old Jun 25, 2010 | 03:07 PM
SmackinJuice's Avatar
Don't listen to them
Engine
2.4 intake manifold $175 + if done yourself
ced I/M $250
2.4 throttle body $150
tsudo exhaust 2.25 3.5 tip $250
ZZP header downpipe combo $470 with highflow cat an o2 bung (bug them for discounts )
comp cams 650,
zzp retainers 190, or supertech for stage 2 cams, 370
trifecta tune 250
roughly 2000 bucks for parts, cause you will need little more than that. anyhow that will get you stage 1 or stage 2 cams, figure 25hp with stage 1, 35hp with 2.
now add in whether or not you are doing this yourself for installing, or having a shop do it (another 1000?)
ballpark figures 185 for stage 1, 195 for stage 2. Ask huckerage though he's stage 2, but he has serious weight reduction, but he got low 14,s before cams, we are waiting for him to get us a good time with them.
so yes with turbo you'd spend the same and get much more; but it's not super expensive like people make it, and you will have a sexy cam lope, and a strong powerband and an extremely rev happy engine.
optional but down the road as your clutch goes to hell
Driveline
Act performance clutch, raceinspired.com $122
exedy racing stage 1 clutch, $280 ottperformance
300 for lightened flywheel exedy racing
also
Traction
OTTP Rotated Trans Mounts $205
Ingalls stiffy engine torque damper $165
TC Strut/Shock, Rack Spacers and Pedders Combo Suspension OTTperformance $600
or ARKS for $189 to $230,
Cobalt FE5 Struts and Shock Pkg FE5-S $280 Crateenginedepot.com
NOTE==========
This is the cheapest route i have found, this is by all means not the best, but a lot of members on here will let you know these products are very good quality, it's by all means not the worst, far from it.
Old Jun 25, 2010 | 03:10 PM
restonSS's Avatar
its really fun to play with a rev happy engine. swap out all pulleys to light ones, lightweight flywheel etc. reving to 8000+ is always a blast.
Old Jun 25, 2010 | 03:13 PM
trey ss's Avatar
put twin turbo im sure youd b the 1st
Old Jun 27, 2010 | 03:25 PM
huckernage's Avatar
i did that. but you need, neutal balance shaft, seat, retainer and 78lbs spring to get over 8000 safely
Old Jun 27, 2010 | 03:29 PM
Gestapo007's Avatar
boost is more fun. /thread
Old Jul 4, 2010 | 03:08 PM
southpaw's Avatar
It can be done - 2 in the uk are over 235hp
Old Jul 6, 2010 | 04:01 AM
alanoo's Avatar
And forged rods... at least
chefhhr
Oct 26, 2015 10:36 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
ThoR294
Sep 28, 2015 05:31 PM
Getaway_Driver
25
Sep 5, 2015 09:16 PM
T-Rex
Aug 27, 2005 03:59 PM
