2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Spark Plugs
Old Oct 11, 2010 | 05:44 PM
DavidLaMattina's Avatar
Spark Plugs
I know i'm posting a million threads lately, but I have a lot of questions!
I want to do the spark plugs, what are the best plugs for the car? any input?
also, I don't see ignition wires, are there any?
Old Oct 11, 2010 | 05:46 PM
ecot3c inside's Avatar
your base model, use stock plugs. They are coil on plug system, so no wires
Old Oct 11, 2010 | 05:52 PM
That's what I thought, thanks! - I purchased Autolite XP-Iridium's, Is that ok?
Also, do i just remove each of the black things on top of the block to access each plug?
Old Oct 12, 2010 | 06:47 PM
RedBaseBolt's Avatar
yep.
It's coil over ignition. Just remove the packs. Remove spark plugs, replace with fresh and away you go. I've changed my plugs in my old car at least 15 times
Old Oct 15, 2010 | 03:03 PM
Rubberdude88's Avatar
Did you notice a difference using the XP Iridium's???
I looked for them at Canadian Tire but the parts counter told me they don't make them for the 2.2 LAP??? Where did you get them?
Old Oct 15, 2010 | 03:19 PM
rnjmur's Avatar
Stay with stock heat range. Other than that, Iridiums or Platinums should work just fine.
Old Oct 15, 2010 | 06:07 PM
I purchased them at AutoZone here in the U.S - they work just fine so far, the car runs/accelerates real smooth, then again the old ones were pretty fried when i took them out.
Old Oct 15, 2010 | 09:15 PM
jbenso4's Avatar
how many miles were on it when u changed them
Old Oct 15, 2010 | 10:54 PM
It as 33,000 right now, and was supposed to be done at 25,000 but i HIGHLY doubt they were done.. I just bought the car a couple weeks ago.
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
717ssbalt
Oct 2, 2015 04:01 PM
CobaltSS 16
Sep 29, 2015 01:53 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
