2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Supercharger build Lap
Old 09-03-2020, 11:32 AM
  #326
Rattlesnake Race Shop
USMCFieldMP's Avatar
Have you still been running them at the factory gap? That'd be surprising; you usually have to close the gap up a bit with boost. I can't remember what my LSJ ran, but I seem to recall it being mid-30's from the factory.
How old are the plugs you have? Personally, I'd swap to NGK plugs. I run them in everything that I own; NGK is top quality.
You could try 50; I measure what your current plugs are and increase a bit from there. You won't notice the difference at idle, it'll be at WOT. When the gap is too big, you'll get spark blow-out during WOT. You can probably adjust your spark dwell in HPT too, but that's getting a little advanced.
Old 09-03-2020, 11:44 AM
  #327
G5ALIVE's Avatar
Oh okay gotcha. Yeah I’ve been using autolites for LE5’s since day one, 44 gap for sure. Actually think stock is 40....
On my second set now they’re about 2 months old.
yeah maybe I’ll look at some l61 ngk plugs, one step colder maybe?
Old 09-03-2020, 12:04 PM
  #328
Probably be a good idea since you've got boost now, but since you're spraying meth, you may not need it.
https://ngksparkplugs.com/en/resourc...rk-plug-basics
IGNITION TIMING
  • Advancing ignition timing by 10° will cause the spark plug tip temperature to increase by approximately 70° to 100°C.
  • A colder heat range spark plug may be necessary if the ignition timing has been advanced to near the knock level. Higher cylinder temperatures near the knock level will bring the spark plug firing end temperature closer to the pre-ignition range.
FORCED INDUCTION (TURBOCHARGING, SUPERCHARGING)
  • A colder heat range spark plug may be necessary due to the increased cylinder temperature as boost pressure (manifold pressure) and subsequent cylinder pressure and temperature increase.
Old 09-03-2020, 12:55 PM
  #329
One step colder for an l61/le5 is stock heat range for an LSJ, so Id say you should run those at least. LTR6-IX would be one step colder iridium plugs. LTR7 is two steps colder(one step for lsj).
They dont really make proper copper plugs for our engine but I have had good luck running LFR6 or LFR7 plugs that use a gasket seat if you want something cheaper. Keep in mind copper plugs need to be changed more often.
Old 09-03-2020, 01:03 PM
  #330
G5ALIVE's Avatar
Thanks for the info guys. I’ll have a look later see what my suppliers got!
Old 09-03-2020, 05:18 PM
  #331
chevygirl2006's Avatar
Run stock lnf plugs. Been running those in my tvs car for a couple years.
Old 09-03-2020, 06:42 PM
  #332
G5ALIVE's Avatar
Well I ordered NGK 6509 before leaving work should be there in the morning. Thread sizes look good, 6 heat range so one step colder for me, ground electrode, comes in a 44 gap and I'll probably try 48-50
edit: now gapped to 0.050
Old 09-04-2020, 06:51 PM
  #333
G5ALIVE's Avatar
So NGK6509 is a pinch smaller than my autolites.. does that sound right?
Old 09-04-2020, 06:52 PM
  #334
G5ALIVE's Avatar
edit: all good I just threw em in lol
Old 09-05-2020, 12:19 PM
  #335
G5ALIVE's Avatar
So this is with full 20 spark top end, min 15 TM. No trans torque reductions and shifting at 6800 rpm, 20psi on the tires.
think I might try pushing Tm min even higher and rev to 6900. Maybe add a degree of spark on top
Old 09-05-2020, 02:01 PM
  #336
G5ALIVE's Avatar
Nope that was all she had. Not bad but still got .4 to go.
Try again in a few weeks
Old 09-05-2020, 06:08 PM
  #337
Get slicks or drag radials
Old 09-05-2020, 09:02 PM
  #338
Monieg5gt's Avatar
omg brotha you are soo close to them 13's. I think next pass once it gets a little cooler out you will get it. So I did get confirmation on Friday from Powell(Gloria) that the YYZ's are delayed due to US border issues. So here is my dilemma lol. I thought about the Eibach Pro Springs Kit instead. Are they as good as YYZ'S? If not then I will just wait. The other issue is that i'm pretty sure one of my rear springs is broke. I'm getting crazy clunky over ever bump now. I just under my car tonight hoping it might just be a loose exhaust hanger but everything was tight on the exhaust.
Old 09-05-2020, 09:08 PM
  #339
G5ALIVE's Avatar
Yeah pretty much same 60 foot.. was a little better though all around.
Idk something still seems off, I feel it still should’ve picked up more mph..
The new spark plugs were great all day at the strip.. but... on my way Home, started getting spark blowout at high rpms. Actually makes a pretty cool sound lol. Didn’t think I would recognize the occurrence if it actually happened.
Old 09-05-2020, 09:20 PM
  #340
G5ALIVE's Avatar
Double check the exhaust hangers I had one that wasn’t even on for the longest time but exhaust still felt supported at the tip..
IMO those are just lowering springs. My lowering springs lasted two years on the car before I, decided to take them off. At this point I would only put Powell on, they’re the only handling spring (again imo). I’m sure they have Bilstein packages in stock but they are worth a pretty penny
Old 09-05-2020, 09:25 PM
  #341
G5ALIVE's Avatar
But thanks dude, it’s progress.
Going to pull a plug though take a look sometime soon, wondering if charge temps could be too cold. Might try the warmer plugs gapped to 0.050
Old 09-05-2020, 09:29 PM
  #342
Monieg5gt's Avatar
Yeah that's what I figured brotha. I'am just going to wait and get the best on my car and get the yyz's once they come in hopefully this month. Yeah ok i'll have a closer look tomorrow in proper daylight and see if any of my hangers is off or loose.
Old 09-05-2020, 10:11 PM
  #343
.050 is a pretty big gap. I would keep the colder plugs and just decrease the gap slightly.
Old 09-06-2020, 12:39 PM
  #344
G5ALIVE's Avatar
Gotcha, I’ll keep an eye on it then
Old 09-11-2020, 07:32 PM
  #345
G5ALIVE's Avatar
New idea here.. Gonna pull my ABS fuse tomorrow see if I get full timing at wot in 3rd, then I could just add a "TM switch." about 80% sure this won't work haha but eh its something to try I guess
EDIT: actually, no need at all. Had full timing today with stock torque reduction table, only thing I changed was 'stall TM,' set those values to 7200 and 7000
So that's a win! I guess that table does more than described... Who knows maybe this all being documented will help someone else who turns VVT off. I believe that's why my TM is being fussy..
Definitely need to close the gap on them plugs though, pretty sure I was shooting flames today lmao, probably start with 48 see how it goes.
Old 09-15-2020, 05:26 PM
  #346
G5ALIVE's Avatar
never a dull moment for me... Adjusted my plugs to 0.047 last night, threw em in, went to drive the car to work this morning. dead miss on cylinder 2 under load. I initially though it was sill spark blowout but brought out the laptop went around the block just now, pulled the coils and I see cylinder 2 has cracked porcelain. So another 30minutes till she's cool and gonna pull em all. sigh. smile.
Old 09-16-2020, 11:42 AM
  #347
NGK's? Did you buy them locally? Still have the boxes?
NGK Spark Plugs (U.S.A.), Inc. warrants that the products, which it sells to the Distributor, seller, reseller, or customer, shall be free from defects in workmanship and materials within a period of sixty (60) days from the delivery thereof to the aforementioned parties.
But also:
PLUG STUDIO / NGK
(TL;DR: you might need to drop to a colder plug)
Double also: are you using an actual spark plug socket, and not a regular 5/8"? I'd assume so, but if you are just using a regular 5/8" (or metric equiv), that can sometimes be the problem, as they don't have the internal bits that hold the spark plug securely (keeping it from bouncing around in the socket).
Old 09-16-2020, 03:41 PM
  #348
Slobodan Milošević
07blackg5's Avatar
.047 is still huge. gap them to .028-.032 and try it
Old 09-16-2020, 05:34 PM
  #349
G5ALIVE's Avatar
I buy my parts locally yes, I work for a Parts department at a Chrysler dealership so yeah warranty would have been totally do-able except they were my 2 months old autolites, not my new NGK6509s.
I did pick up another set of NGK 6509's yesterday just in case for whatever reason. & Decided to gap them to 0.046 today and they're going in tonight.
But also:
PLUG STUDIO / NGK
NGK6509's are a onestep colder for me.
Yup I got an actual spark plug insulated socket
Old 09-16-2020, 05:39 PM
  #350
G5ALIVE's Avatar
That didn't come out right...
But no I don't think over 0.04 is that big for my mods. Car was running fine with 0.044 just had a little bit of blowout at 6600 rpm ish with 0.050. So I'm sure 0.046 will produce no blowout.
Quick Reply: Supercharger build Lap
