2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
thermostat below temp??
Old Sep 14, 2011 | 11:12 PM
Schneids's Avatar
so ive had this code come up like 3 months ago and i just erased it and never showed up untill last week again same code says thermostat below tempature? have any of you ran into this code before? things on the internet say its from the fan being on a lot?
Old Sep 14, 2011 | 11:16 PM
ben_gary's Avatar
how many miles? might need to replace the stat
Old Sep 14, 2011 | 11:24 PM
Schneids's Avatar
155,000km thats what i was thinking going to replace thermostat and go from there
Old Sep 14, 2011 | 11:26 PM
ben_gary's Avatar
mines went out at about 90k-miles
Old Sep 14, 2011 | 11:27 PM
Schneids's Avatar
so all it did was toss same code?
Old Oct 8, 2011 | 12:25 PM
IonNinja's Avatar
how involved is the thermostat replacement?
Old Oct 8, 2011 | 10:13 PM
ben_gary's Avatar
on lsj its located behind the motor on the drivers side by the header. "only three bolts". but to get to one is a lil difficult.
Old Oct 10, 2011 | 10:35 PM
IonNinja's Avatar
im assuming you're gonna need something to catch the coolant once you get to the 3 bolts?
Old Oct 10, 2011 | 10:39 PM
BlackARCA06's Avatar
Yea, it'll come pouring out. Then just refill through the coolant tank.
Old Oct 16, 2011 | 01:51 PM
IonNinja's Avatar
good times...mine is throwing the same code so I should be replacing it soon
Old Oct 16, 2011 | 10:16 PM
sLAsh's Avatar
If it's like most gm's it is worth changing the thermostat sooner rather than later. If the engine doesn't get up to temp it never goes into closed loop and will use more gas
Sean Cummings
Mar 9, 2018 12:26 AM
anotherslowlnf
Sep 29, 2015 03:52 PM
z28addiction
Sep 28, 2015 12:03 AM
jmelton327
Sep 26, 2015 10:04 PM
medic710
Sep 6, 2015 08:53 PM
