2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Throttle body cleaning
Old Dec 30, 2010 | 11:27 PM
09Balt's Avatar
What would be the best solution to cleaning out a cobalts throttle body?
Old Dec 31, 2010 | 08:48 AM
C_A_D88's Avatar
take it off spay it with tb cleaner and clean it
Old Jan 1, 2011 | 08:44 AM
09Balt's Avatar
I s there a way of cleaning it without taking it off what if i got a toothbrush and sprayed alittle carb cleaner on it and scrub it when it was cool
Old Jan 1, 2011 | 01:18 PM
C_A_D88's Avatar
why not just take it off? its like 4 bolts or whatever it is
Old Jan 1, 2011 | 10:46 PM
09Balt's Avatar
I'm not to sure from what i hear when you take it off and clean it you will have some problems with it idle and when you increase your speed
Old Jan 1, 2011 | 10:54 PM
kxrida2000's Avatar
1. use throttlebody cleaner not carb cleaner
2. take it off u dont want **** goin down ur intake
3. dont spray it directly, take a rag and spray it and then wipe it....you can ruin the electrical connection if u accidently get a drop on it
Old Jan 2, 2011 | 09:39 AM
C_A_D88's Avatar
meh took mine right off,, sprayed it directly ..sall good no issues
Old Jan 8, 2011 | 09:33 PM
07Maliboo's Avatar
the electronics on these are durable, a little cleaner wont do anything to it if it's not powered right away. and if you're taking it off nothing will ruin ur idle, that's only when you pnp it. which is also really easy btw, and does help for a mild throttle response increase as well as a tad deeper tone. it's a cheap way to get minor gains compared to buyin a new bigger tb.
Supercharged06SS
Dec 11, 2022 04:47 PM
Oct 20, 2015 09:56 PM
dennis69
Oct 20, 2015 04:49 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
