2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
turbo help
Old 02-27-2013, 01:34 PM
mikesbalt's Avatar
turbo help
i could really use some help im trying to turbo my 2010 cobalt LS 2.2L i dont know what all i need to turbo it i have the trifecta tune figured out but i dont know what all i need turbo kit wise i have forund the ZZperformace kit but im not sure what else i will need any help would be appreciated
Old 02-27-2013, 01:37 PM
BankerBalt's Avatar
gauges, a better tune, bigger catback
Old 02-27-2013, 07:56 PM
mikesbalt's Avatar
Not quite the response i was looking for but i kinda posted for generics
I need to know what tune to get from where what guages kinda specifics
Old 02-27-2013, 08:00 PM
06_CobaltLS's Avatar
Depends on how much you are willing to spend for each extra item on top of the turbo kit.
Old 02-28-2013, 12:33 PM
mikesbalt's Avatar
The cost isnt important i just need a list of what else i need other than the tune turbo kit from zzp and a new clutch
Old 02-28-2013, 12:50 PM
rcarr0327's Avatar
If you are going with the ZZP Kit for sure then that covers a lot.
Clutch:try Turbotechracing.com. a lot of people like KY Clutches and theyre not that bad
Gauges: Air-to-Fuel Ratio (AFR), I used a digital AEM Gauge. Boost Gauge, autometer, AEM, Glowshift, the list is endless. probably an Oil pressure gauge as well, same brands as listed before.
I liked having the AEM Digital AFR gauge with autometer boost and oil pressure Analog and mechanical.
Tune: you can go with Trifecta but some people dont like it and end up switching to HP Tuners.
Catback: whatever you want really.... 2.5" minimum id say. ZZP, Turbotechracing (TTR), Modernperformance (MPx), Tsudo, GM Performance Parts (GMPP) from crateenginedepot.com
Tires
Either a ZZP modified oil pan or take yours off and weld in a bung for oil return.
like i said, ZZP kit covers a lot of the necessary items. only really thing necessary after that kit is a tune. I had the ZZP and bought gauges, oil pan, gauge pod, and tune. later on i got tires and wheels and springs
Old 02-28-2013, 12:53 PM
574's Avatar
Tires
This, spoon fed information. Not everyone is gonna do this... do some research man... do it right and turbo 2.2s are fast . Good luck
Old 02-28-2013, 03:03 PM
Some people have good and bad luck with different gauges. I bought pro sport premium series boost gauge and digital AFR wideband and they work/look amazing. As far as a tune most people go with HPtuner for the 2.2s 07-up. Trifecta has problems with being too busy to get a data log modified and sent back and with HPT you can either get a dealer to come out and modify everything there or you can do it yourself. If you're an automatic then I recommend the B&M shift kit+ for stiffer shifts and a nice transmission cooler. Not sure about manuals since I'm auto as well. You will definitely want upgraded /wider tires to be able to hook up, otherwise you'll be spinning like crazy and wasting tread. Recommended cat back size for a turbo is 3.0" but you will be just fine with 2.5 or even 2.25 for little bit but not long. Plenty of great brands listed above by rcarr. Its easier to buy most of the misc parts from ZZP directly, such as: gaskets(if not already supplied with kit), ZZP oil pan with bung and fitting installed, and gauge pod/pillar and any other supplies you need. Its mostly self explainatory. Just do your research man, there's plenty of good turbo how-to's on here you can read up on for more info. Just be expected to upgrade your internals eventually as they are not rated for being boosted for very long. Some people have gone a week and blew up their motor and I know a guy who ran 291 HP on his 2.2 stock motor for well over a year. Good luck and don't be afraid to ask ANY questions you have, even if you think they are dumb questions. We are always happy to help fellow members.
Old 03-01-2013, 01:43 PM
rcarr0327's Avatar
yea i was boosted for 2 years at 8psi and fine. my pistons are a little black but still good compression
Old 03-03-2013, 12:44 PM
mikesbalt's Avatar
anyone know where to get forged rods and pistons a meatier crank better cams or valve springs and retainers boost rated stuff that is lol want to do this right i already ordered the turbo kit oil pan gaskets and arp head studs
Old 03-03-2013, 12:55 PM
nhanson's Avatar
What are your goals?
You dont necessarily need to build the motor if you only want to be a little more quicker.
Rods and pistons get from Turbotechracing.com
Valve springs from ZZP
You dont need a crank
Get a stock head gasket (new one)
Old 03-03-2013, 12:56 PM
mexi_loco's Avatar
you really won't need to do an engine build if you keep the boost low enough. But, if you're really interested, I have a friend that has a fully build 2.2 block for sale. It's a 10:1 compression ratio, but very well built. If you're really serious, I'll let him know and you can deal straight with him.
Old 03-03-2013, 05:28 PM
rcarr0327's Avatar
a lot of people buy the wiseco pistons and eagle rods kit on ebay for like 800 bucks. 8.9:1 compression ratio.
Old 03-04-2013, 07:01 PM
stenguyen1's Avatar
yea bro if you want a built motor i got one for sale for 4000.
check out my thread.
https://www.cobaltss.net/forums/part...ywheel-293715/
Supercharged06SS
12-11-2022 04:47 PM
05-28-2022 03:47 AM
hacadacalopolis
10-28-2015 06:09 PM
patooyee
10-15-2015 05:11 PM
maliki778
10-01-2015 07:39 PM
Quick Reply: turbo help
