2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
Turbo install on 2.2
Old Oct 28, 2010 | 07:34 AM
HHR-2009's Avatar
Thumbs up Turbo install on 2.2
I was wondering if any one can help, I will be installing a Turbo LNF on my 2.2 2009, and was wondering where do you get the oil from to suply the Turbo, I don`t want to reinvent the wheel, it will also save time for the mecanic to install the Turbo system.
Thanks
Old Nov 7, 2010 | 08:37 PM
07Maliboo's Avatar
usually its tapped from the oil pan. That involves dropping the pan, cutting a hole, and welding in a bung to which you can screw in a threaded line. that's your best option.
Old Nov 7, 2010 | 09:23 PM
HHR-2009's Avatar
Would that be the return or the feed towards the turbo
Thanks for your help, the mecanic who will be doing the job has already done a few Honda's, but not sure if he's ever done a chevy
Old Nov 7, 2010 | 10:11 PM
BlackCobalt707's Avatar
according to the garret kit, there is a galley plug on the block you take off for the oil feed. i went a different route and tapped mine from the head cause otherwise my line would be hittin exhaust. but the oil pan is for the oil drain
Old Nov 8, 2010 | 06:51 PM
HHR-2009's Avatar
Great info, thank you so much , I will search for the location of this plug on the back of the engine
Thanks again, this forum is the best
Old Nov 8, 2010 | 07:23 PM
its right under the header. ill see if i can get you a pic
here is a pic. there are 3 plugs that you need a torx key to use on. that screw that is stickin out the block, look directly over and that is the galley plug
http://i186.photobucket.com/albums/x...gineblock3.jpg
Old Nov 10, 2010 | 06:28 AM
HHR-2009's Avatar
Thumbs up
Thank you so much, I will check this out on my block
Old Dec 23, 2010 | 12:14 AM
09blackonblack's Avatar
you will also need the coolant crossover tube...
Old Dec 25, 2010 | 09:34 AM
HHR-2009's Avatar
I didn't think LNF TURBO used water, I thaught it only used the oil lines to and from.
It's not yet installed, these are the parts I have for this project
- LNF Turbo assy
- HHR SS intercooler
- HHR SS all the pipes from and to Turbo
- cold plugs (gap .32)
- 3 '' DP no Cat ZZP
- GMPP Cat Back
- Tune (Trifecta)
- will be installed on a 2.2 2009, want to keep the boot at 8psi
- 42 injectors plus cable (not sure yet if the cable is compatible with my 2009)
If any one with experience think of something I maybe missing, please feel free to add to my list.
thanks
patooyee
Oct 15, 2015 05:11 PM
Tupp
Sep 30, 2015 08:18 PM
Dylan Johnson
Sep 30, 2015 08:57 AM
