2.2L LAP Performance Tech 2.2L LAP Performance Tech (2009+) 155 hp EcoTec with 150 lb-ft of torque
You follow the oil life?
Old Aug 6, 2013 | 03:32 AM
unijabnx2000's Avatar
Do you change it when it tells you to, or do you do it every Xxxx miles?
Old Aug 8, 2013 | 05:43 PM
owlwyn's Avatar
depends if you use synthetic or not. I've noticed by the time my mileage has reached the 5-6k I run on synthetic my oil life is rather low too. but I say go till the miles, since my oil is starting to get dark so I change it.
Posted from Cobaltss.net App for Android
if that makes any sense.
Old Aug 8, 2013 | 05:51 PM
To start off with I changed it when I got to 45-50%...
To start off with I'd go 10-12k miles and I still changed it by 45%. That was crazy IMO
Then slowly started changing it sooner.
Now that its passed 100k, I change it at 60%.
As much as I want to trust the meter... Going that long on the oil seems crazy to me.
Old Aug 9, 2013 | 06:45 AM
owlwyn's Avatar
yeah, I've never had it longer then 7,000 and I was getting annoyed at myself for not getting it changed yet.
Old Aug 9, 2013 | 06:48 AM
Only way to know for sure is to get a used oil analysis, more than likely the stock oil monitoring system is solid if you use the recommended oil, or synthetic oil. If you are concerned spend the 35 on a UOA from blackstone labs
Old Aug 18, 2013 | 12:45 PM
John Mudd's Avatar
I use full synthetic and change around 30-40%. Car runs fine, top end of the engine looks fine with the valve cover off, so I have no need to change any sooner. 80,000 miles.
Old Aug 18, 2013 | 12:50 PM
redcobalt07's Avatar
I let it get to 1-2%
Old Aug 18, 2013 | 12:51 PM
chris88z24's Avatar
Yup.
Old Aug 18, 2013 | 01:02 PM
I dont drive much it usually gets to ~20% before i change it but its only like 2 times a year
Old Sep 5, 2013 | 04:10 PM
qwank's Avatar
3,000 miles no matter what oil or driving conditions. no exceptions here.
Old Sep 5, 2013 | 04:15 PM
emiller's Avatar
If you are just gonna throw away money then buy us all some beer.
Old Sep 5, 2013 | 04:19 PM
Kyle09TC's Avatar
I use the oil life meter
Old Sep 8, 2013 | 10:15 AM
qwank's Avatar
it's $25 for 5 qts of mobil one at walmart. and I get oil filters for free at work. I've seen what happens to these engines when people wait until the oil percentage is down to 0% every time. GM even had a recall on a ton of vehicles to shorten the time the monitor counts down because of this.
$25 every 8 weeks is no big deal to prevent sludge and my VVT actuators and solenoids from sticking, and timing chain stretch.
Old Sep 8, 2013 | 10:17 AM
Another one?
Old Sep 8, 2013 | 11:10 AM
z062007vette's Avatar
I let it get down to the 20-35% range. Depends on where I'm driving and such and if I have any trips planned.
Old Sep 8, 2013 | 11:14 AM
emiller's Avatar
3k is still way more than needed. Why not get your oil analysed and judge for yourself? Plenty of people on here have.
Old Sep 8, 2013 | 11:18 PM
andrewcarr1993's Avatar
I use royal purple and normally take it about 20-30% then change it. I'm currently at 34% and want to run it out since when I turbo it I'll replace the oil, not wanting to waste $50 when I'm spending as much as I am
Old Sep 8, 2013 | 11:22 PM
SalvageBaltSS's Avatar
All the cars I have I change the oil in, its every 5,000 .
Old Sep 11, 2013 | 09:59 PM
05g5's Avatar
Either my indicator is off cuz i put on 4-5k kms a month. And my meter goes down to like 75% by that time.. If that
Or its based off time AND kms.
Every 5000 kms
I drive it hard, i dont wonna pay lots for avoidable problems.
Old Sep 11, 2013 | 10:07 PM
the thing is the more often you have new oil in the motor, the mire time you have oil that isnt settled in at its proper viscosity.
i change mine between 50% and 25% though since i drive her hard
Old Sep 11, 2013 | 10:28 PM
Xmetalhead2003X's Avatar
I run 30k mile amsoil with 15k filter. I change once a year and just slightly under 12k since last change. I also throw seafoam in there a few hundred miles before change too. I end up resetting the meter a few times in between. Runs strong.
Old Sep 11, 2013 | 10:34 PM
Beamer's Avatar
used to change it when it got in the 60% range. By that point it was around the 4 month mark. I did not put typical miles like most on mine which if I did use mileage it was probably 2k-2k5 miles. With stop and go traffic along with fun driving I did not want to push it.
Old Sep 11, 2013 | 10:40 PM
Spawne32's Avatar
waste of money, most full synthetic oil wont even begin to show signs of break down until at least 5000 miles, rotella T6 is good up to 10,000+, laboratory tested by customers to test that fact.
Old Sep 11, 2013 | 11:00 PM
drtibalt's Avatar
I change mine every 3-5000 kms
Old Sep 11, 2013 | 11:09 PM
iToastie's Avatar
5,000 miles, no exceptions
