07 vs. 08 PCM
Old Apr 6, 2009 | 08:11 PM
ss/pumkin's Avatar
07 vs. 08 PCM
For a 2.4L Auto, difference from 07 to 08?
Old Apr 6, 2009 | 11:25 PM
Red07SSNA's Avatar
The only 08 Sport I've had a chance to look at had an ECM with only 2-top-to-bottom connectors, whereas my 07 SS/NA's ECM has 3-top-to bottom connectors (not including the TCM connectors).
It is interesting to note that the Jet performance modules fit both the 07 and 08 ECMs...so it appears the middle conector on the 07 ECM is the same as the bottom connector of the 08 ECM.
Old Apr 6, 2009 | 11:33 PM
Dunkinuts's Avatar
enough is different that no software or anything like that can be swapped between them.
Old Apr 7, 2009 | 02:29 PM
DaBuzzard's Avatar
07 and prior can be tuned with HPTuners, 08 can't........yet
LS2 edit claims to be able to tune the 08's, if that is why you are asking.
TedSS
101
Apr 25, 2016 10:46 PM
Sean Cummings
Cobalt SS Vendor Reviews
Nov 30, 2015 06:36 PM
n20saturn
Sep 21, 2015 01:50 AM
DevZX
Sep 16, 2015 06:19 PM
BettyBlue2.2
Sep 10, 2015 08:49 PM
