2.4 with 2.0 lsj head?? help!!
Old Aug 2, 2012 | 02:54 PM
07SS2.4's Avatar
Question 2.4 with 2.0 lsj head?? help!!
guys i have a 2.4 ss and want cams but i dont want to have custom ground cams. i just want to get a 2.0 head and build it up for a s/c and put it all on at once. im just wonderin if thats possible???
Old Aug 2, 2012 | 03:01 PM
chevygirl2006's Avatar
Buy the cams from zzp
Old Aug 2, 2012 | 04:08 PM
klotzy_550's Avatar
The possiblility of putting a 2.0 head on a LE5 is very doubt full, the LNF head will not work because It is has direct injection and our computers cannot control those functions. If you were refering to an LSJ head, it still more than likely will not work because our heads have variable valve timing where the LSJ's doesn't, so that would already **** off the ECM because I know it has sensors for the cams that the LSJ did not. Chevygirl2006 is right, just buy some cams from a aftermarket dealer. And yeah, I'm agreeing with a woman...lol
Im not 100% sure on this here but I believe you can make a 2.3L and 2.1L LEJ/LS5 hybrid but I believe that is by swapping out the crankshaft from one to the other or something down that road. But I am pretty sure the LSJ valvetrain/head will not work on the LE5.
Update: it is possible to put a LE5 bottom end in a 2.0 LSJ based car. If it is possible to do it on a 2.4 based car, im not sure, but the way it sounds is that the ecm would have to be swapped with that of the LSJ's.
In the lond run buying aftermarket cams is a much easier route to go. Either way food for thought and best of luck if you do it!
Old Aug 2, 2012 | 08:38 PM
hhrfreek's Avatar
Wasn't it user Newt that had an LSJ/LE5 combo?
Why do you want to do an LSJ head? Pull your head, port it(especially exh side) and call it good...it will flow like mad. ZZP 2.4l cams are a nice touch though too.
Old Aug 2, 2012 | 09:17 PM
nhanson's Avatar
Port head, get cams. Tune the VVT
Old Aug 2, 2012 | 09:27 PM
hydrid 2.2 head le5 bottom ends have been done on jbodies. i know one guy on here swapped the entire le5 into his LS balt. You might need to use a crank trigger wheel, do some more research
Old Aug 2, 2012 | 09:43 PM
LS6Rally's Avatar
He ahs a Sunfire, which doesnt come with VVT so he can use what he wants.
with the VVT it seems you would need to run a standalone computer, ZZP sells cams for our cars, compatible with the VVT
Old Aug 10, 2012 | 02:23 PM
newt's Avatar
True story.
I have a LE5 bottom end, LSJ head in a sunfire.
Biggest problem would be getting it run right with the computer in a factory equipped LE5 car.
Other than that its not to hard of a combo to put together.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
Trav3480
Oct 1, 2015 08:17 PM
Sep 28, 2015 12:51 PM
