2.4 LE5 GM Pro CAMS
2.4 LE5 GM Pro CAMS
i got my cam from JPB but it will void warrenty so i am selling it to a friend
Question the GM Pro cam will not void warrenty but will i see a good gain. still plan on goinf with intake downpipe and header
The CAM will be limited as it will not be as performance orentated as the JPB one. The Duration, Lift will ultimately be not to same performance spec as GM's.
you put the Jbp cams in your dealer wont ever know,this is what my tech told me, they would have to have it on some machine or somthing to tell and that means opening it up, **** dont sell your cams
Installing GM cams will affect your warranty. GM isn't going to warranty an engine tore into even if it's to install a GM part, GM warranties the performance parts themselves, don't confuse that with GM performance parts retaining the factory powertrain warranty on your vehicle.
dont expect to get any warranty on this car...alot of the dealers surf the forums. they know what you are doing.
a dealer would definately be able to notice the rough idle associated with a large overlap...and the tool marks from taking off your cam cover.
cams are a big item to go putting on your car, GM or not...your warranty will be void.
what about if i go to GM and told them my friend bought them they would install and warenty would be good.. is this possable or can they tell the diffrence between gm and jpb cam. even if they have never seen one befo the guys there told me they never did one before. i also told them i was gonna get the cam from a dealer 400km away they said it was fine.
Yes but are YOU a current CERTIFIED GM mechanic? there is no conversation here. If they can find out, beyond a reasonable doubt, that you have dug into their motor, they wont cover anything. PERIOD.
ok guys, if you mod your car to the point of putting cams in and end of having a problem, man up and pay the price it takes to play. IF you are worried about your warranty don't mod your car, it's that simple.
So wheres the info on these "gm magic cams"? Im searching and only seeing referances to jbp.
im not saying you dont know what the **** your talking about... im just saying point me in the right direction...
actually technically they legally MUST keep the warranty active unless the cam actually causes the failure you want the warranty to fix. as long as it is installed properly (and get a tune to be safe) you shouldn't worry about the cam causing damage, but then again, alot of dealers will say, "that's not warrantied" then people just give up. if they try to push it off on you argue it. yell in the show room in front of customers and talk about how bad their service is. do what it takes, because legally they have to keep their warranty active unless your mods actually cause the failure.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
