2.4 mild NA build
Old 02-24-2015, 08:49 PM
  #76
Spawne32's Avatar
Soon as you get measurements, get back to me, im curious as to how they compare to what I had bought. The LSA i find puzzling because stock LSA is 130 on those cams.
Old 02-25-2015, 08:59 AM
  #77
mrbelvedere's Avatar
base circle
int cam 1.11 28.6mm
exh cam 1.11 28.6mm
lobe height
int cam 1.37 34.9mm
exh cam 1.35 34.5mm
there is 0.0197 difference in lobe height
Old 02-25-2015, 12:01 PM
  #78
Spawne32's Avatar
Originally Posted by mrbelvedere
base circle
int cam 1.11 28.6mm
exh cam 1.11 28.6mm
lobe height
int cam 1.37 34.9mm
exh cam 1.35 34.5mm
1.4mm off the base circle (stock is 30mm) you should be perfect with the ZZP stage 2 lash adjusters, id run them on both sides IMO. That's good that they were able to maintain that on the exhaust cam as well. My exhaust cam was measuring in at 27.3mm on the base circle which is what lead to the premature cam wear and the monstrous ticking noise I had even with the ZZP s2 lash adjusters. Which is why I wound up sending them back to delta, not only that, they refused to give me any specs on opening and closing events.
If your engine sounds like this after installing them, you will know.
Old 02-25-2015, 04:45 PM
  #79
a 0.1000 is the tipping point on the valve geometry he said they removed .060 of the base circle we will soon see how it runs
Old 03-03-2015, 04:21 PM
  #80
CordiaDOHC's Avatar
Would love more aggressive cams. But picked up an LNF exhaust cam. Just going to run that. Let the sc make up the rest of the power
Old 03-04-2015, 12:41 PM
  #81
toolman's Avatar
I'm curious about the kind of oil you used (pre-rebuild) to get that much sludge buildup.
Old 03-04-2015, 01:08 PM
  #82
Spawne32's Avatar
From the records I have on the car, nothing but walmart service center oil changes for the past 126,000 miles. lol That's the reason why as soon as I bought the car I serviced everything, including the trans.
Old 03-05-2015, 09:55 AM
  #83
sludge is created from not getting the oil hot enough to burn the moisture from the oil. a lot of short trips will cause it and all oils will create sludge
Old 03-27-2015, 08:06 AM
  #84
i either have a bad lash adjuster or non true base circle on 1 cam lobe it holds the valve off seat
Old 03-29-2015, 01:04 PM
  #85
nhanson's Avatar
What did you modify for VVT for the LNF cam? I have it installed now
Old 10-19-2015, 08:42 AM
  #86
Robbo's Avatar
Does a 2.4 cobalt have forged pistons?
Old 10-19-2015, 08:56 AM
  #87
Administrator
Administrator
Staged07SS's Avatar
No... some years had forged rods, but not pistons.
Old 10-19-2015, 10:48 AM
  #88
no ecotec comes with a forged rod
Old 10-19-2015, 10:59 AM
  #89
Administrator
Administrator
Staged07SS's Avatar
Huh?! I thought the LSJ and LNF have forged connecting rods...
Old 10-19-2015, 11:00 AM
  #90
Okay, Mr. Technical.
Old 10-19-2015, 11:53 AM
  #91
According to gm they do.
Old 10-19-2015, 11:56 AM
  #92
Administrator
Administrator
Staged07SS's Avatar
Yup... all my GM documents (build book, Bill Duncan, numerous spec sheets, etc.) claim they came with forged connecting rods.
If it's wrong I want to hear Johns (mrB) take on it.
Old 06-09-2016, 03:30 PM
  #93
Cobalts&Peaveys's Avatar
Originally Posted by noorj
still can't put down as much power or be as reliable as a turbo lsj. turbo le5's can really only be around mid 300's and still reliable, where a turbo lsj can sit at 400-450 reliably and still have room to grow.
Actually, you can build an le5 to around 350 hp before you even drop it in the car. Look up Roush Ecotec. It's not really news anymore. I'm just happy to finally see somebody doing this **** correctly, instead of just boosting everything. I'll be coming into money in the near future, and I'm now physically disabled, so I cant really turn a wrench anymore, so I'll be having someone do the build for me. This engine is the best platform available. Honestly, I would rather have a 4.3 Vortec in my Cobalt, honestly. With RWD. Maybe a 4.3 Ecotec? Since I don't have that much money, guess I'll have to make due.
05-28-2022 03:47 AM
patooyee
10-15-2015 05:11 PM
Jimmy Beilfuss
10-05-2015 04:18 AM
09-26-2015 06:44 PM
Quick Reply: 2.4 mild NA build
