2.4L Auto DP Vs LSJ DP
Old Jun 13, 2009 | 10:52 AM
  #51
hailcesar75's Avatar
Cool them my dp should fit with no problems
Old Jun 13, 2009 | 01:16 PM
  #52
blackbolt89's Avatar
Originally Posted by hailcesar75
thats wierd. i just looked at my dp and the cat is about 2" away from the sway bar. cant see how the lsj dp wouldnt fit. seems like theres alot of space there. also the bends above the cat are to the drivers side and not the bottom which makes it look like the whole dp is going to the drivers side a bit and not straight down. i have the xtc dp and pretty soon will be installing it. ill keep you guys posted but i think the xtc dp will bolt on with no problems
the LSJ cat is roughly 2 inches bigger than the L61 cat and the bend on the manual is completely different than in an auto.
and i was actually wondering the same exact thing about the XTC dp cause i might be picking one up soon.
although now that i look at the difference in the DPs i see that the LSJ cat is indeed a fail and that the high flow cat on the XTC is MUCH smaller on the bottom it only look about a half inch to an inch wider than the pipe. where the lsj cat is like 2-3 inches. http://cobalt-addiction.com/products...ipe_large3.jpg
so without a doubt the XTC should definately fit.
tell us how it goes cesar
Old Jun 13, 2009 | 01:36 PM
  #53
So in that pic the middle one is the one that I got. But it looks as the cat is higher than on the ss/na or the lsj dp. That wouldn't be a problem touching the cat heat shield?
Old Jun 13, 2009 | 01:42 PM
  #54
i'm gonna have to say that even with the heat shield the cat still looks a **** ton smaller than the lsj cat.
but im just speculating there.
and how much life do people normally see out of an aftermarket dp?
cause i'm looking at one that has 40k miles on it and i want to make sure that i won't need a new cat in like 2 months. lol
Old Jun 13, 2009 | 02:29 PM
  #55
Well I hope all goes well. I'll keep ya posted and take pics too
Old Jun 13, 2009 | 02:33 PM
  #56
alright man. cause i'm like 60 miles from picking one up that was meant for a manual.
and btw i love the way your sedan looks.
i'm actually beginning to love the way the sedan rear end looks.
all these coupe owners be hating cause it doesnt have 4 taillights. i kinda like the two. it looks hella clean.
Old Jun 13, 2009 | 02:56 PM
  #57
Hey thNks for the words. I'm thinking of changing my rear lip and getting the g5 rear lip. It looks better IMO
Old Jun 13, 2009 | 03:10 PM
  #58
and it should fit no problem cause the taillights are the same aren't they?
Last edited by blackbolt89; Jun 13, 2009 at 03:10 PM. Reason: Automerged Doublepost
Old Jun 13, 2009 | 03:51 PM
  #59
Nah it's a g5 "lip" only. Not the whole bumper. It almost looks like an evo x when installed.
Rk sport makes it. Check out their website
Last edited by hailcesar75; Jun 13, 2009 at 03:51 PM. Reason: Automerged Doublepost
Old Jun 13, 2009 | 07:10 PM
  #60
OOOOH
i thought you meant the whole rear fascia off a G5
this one? http://rksport.com/main/part_detail....did=14&catid=4
or this one? http://rksport.com/main/part_detail....did=48&catid=4
cause the G5 one looks sex!
Last edited by blackbolt89; Jun 13, 2009 at 07:10 PM. Reason: Automerged Doublepost
Old Sep 13, 2009 | 12:42 PM
  #61
yogilours's Avatar
i want to know if the dp hhr turbo automatic will better fit on a 2,4L automatic than the dp lsj
Old Sep 13, 2009 | 03:47 PM
  #62
the turbo downpipe won't fit a n/a ecotec. at all. iirc
Old May 16, 2010 | 01:07 PM
  #63
slobalt08's Avatar
i know i'm bringing this up from the dead, but i just wanted to say that i have an lsj dp on my 5spd and i had exhaust put on. i had bought a 2.5 magnaflow cat to replace the stock cat, and the exhaust guy said he couldn't put it on cause the pipe is about a 3". i was wondering what i should do now? would i be better off just selling the magnaflow cat and leave the lsj dp as is, or should i get a 2.5 aftermarket dp? if aftermarket, which is the best 2.5 dp i can get?
Old May 16, 2010 | 09:17 PM
  #64
Staged07SS's Avatar
Administrator
Administrator
To anyone who has been told the lsj downpipe is 2.5" .... that is wrong. The actual size is 2.78" o.d. I measured mine when I had it off the car a few weeks back. The small neck down portion at the end of the downpipe (right before the 2 bolt flange) is 2.38" o.d.
Old May 16, 2010 | 10:48 PM
  #65
slobalt08's Avatar
yea i wish i knew that before i bought the cat... >_<
Old May 17, 2010 | 07:22 AM
  #66
Staged07SS's Avatar
Administrator
Administrator
Yeah that sucks man. I don't know what genious on this site made up the size of 2.5" for the stock lsj downpipe, but they couldnt have been more wrong. I always knew the downpipe was 2.75". I just wanted to finally confirm it with actual measurements.
06MetallicBalt
Jul 20, 2025 08:47 PM
Supercharged06SS
Dec 11, 2022 04:47 PM
ThoR294
Oct 4, 2015 08:44 PM
Sep 28, 2015 12:51 PM
