2.4L Supercharged build started
#302
Here are the pictures:
Gray - Bracket and Idler from Rebel
notice the lack of washer fluid connection in the last picture! i'll have to get a LSJ reservoir to put in the fender wall
#304
just a question does the supercharger spin the same way as on a 2.0? because if not there is the problem
also when boost from the manifold goes into the bypass actuator it opens it up. thats why on a 2.0 it goes to a solinoid that doesnt release presure to the actuator untill 12 psi
#307
Thanks for the kind words everyone on the install. Like I said before we worked hard to make this thing look like a bone stock lsj car, and we're very happy with the result
Supercharger definitely spins the same way as the lsj. Already on the tail of the boosting problem... as soon as pjk91 brings her back into the shop we will have the problem solved!!! look for updates next week...very excited to see the final numbers as im sure you all are as well. Again thanks for the kind words
~Fred Jr.
~Fred Jr.
#309
like everyone else said, cant wait to see the results
quick question, do you think this will pass smog in CA, this is the only thing keeping me from upgradeing to SC
#312
The intake is the stock intake off a 2.0 ss/sc. Still waiting on my RD Fabs intake to come in. I have a 2.0 ss/sc TB coming in too, but it's not completely necessary. I got it on eBay cheap.
#315
#317
Honestly, probably not. Based on some of the questions you have been asking, I would say no. You're looking at 10-12 hrs of labor depending on how clean you want the install to be.
#321
im def following this thread closely...once i get my job with chevy...ill be probably going supercharged...me and my buddy can def do the install and then tune with hptuners..keep us updated man!
#323
i had the lsj TB hooked up as well and when i tried to turn the car over the first time it started and then immediately shut of, it triggered 3 engine codes, all TB related.
the DIC then read "Engine Power Reduced" and "Engine Disabled" it would flash between the 2 messages.
the wiring connector is a direct fit, but the lsj TB was pinned differently from the factory.
#324
i dont mean to be a buzz kill but this info is completely wrong
