2.4L Supercharged build started
#126
i got the m62 blower(350.00shipped)....bosch ic pump(89.00 shipped)..stock pulley, belt, and ss/sc injectors(60.00shipped)..dats what i got so far....im getting some more parts soon and whatever i cant get im buying of rebel
and i just bougt an a/f ration gauge for 25.oo
Last edited by Jimmys2007CobaltSS/C; 08-23-2007 at 11:47 PM. Reason: Automerged Doublepost
#127
#128
oh never thought about that i bought it off some guy on the site....do u need a certain one..im going to get a wideband and boost gauge in the future,, i got i/c pump of ebay ...rebel linked it to me and i bought it,,, pm rebel if u need help or any questions...hes a good guy.. I got a really good deal on the blower...its heavier than i expected..25Lbs lol....
we have to use a stg 2 belt ...so my stock belt is no good,,but it came wit the pkg i got
#129
#130
im using the stock 2.0...and stock pulley for now,,i want to see if any1 like senior brown or pjk91 runs a smaller pulley and its safe b40re im doing any of that....it dyno at almost 230whp with the an exhaust and intake...i just added a zzp header and 3"d/p with cat today and it sounds badass....really loud...i cant wait for it to break in bo4re i really floor it...def felt the gain to the wheels right away
def can be close to 240 to 250 whp with the zzp products
Last edited by Jimmys2007CobaltSS/C; 08-24-2007 at 12:02 AM. Reason: Automerged Doublepost
#131
#133
We can only guess what we are going to hit WHP. I have no idea what I'll get. I'm going with a completely stock 2.4 motor with the M62 components and I'll see what I can get out of that. I also have the 42lb'ers because I definitely plan on upgrading in the future.
#135
I have the 34'ers as well. I originally bought those because I was going to do a N/A build but then this option came up so I'm going to stick with the 42'ers.
#137
I'm putting in the LC-1 right now. It's taking way longer than I wanted it to because:
1) Couldn't find electrical tape ANYWHERE in the house
2) Couldn't find a 7/8" open end ANYWHERE ARRGGHHHHH
but I'm ok now. Just waiting for a second set of hands to come help pull the wire.
Believe it or not, still doing the LC-1. There are quite a few wires to extend in their harness, solder at each point, and then find the input on the ecu....
#139
Last night we got the Intake manifold and new alternator on. Got the belt off too. Realized that the intake manifold that I purchased is missing a bracket that is at the bottom of it that braces the manifold against the block.
The LC-1 was a nightmare. I rigged it temporarily just to calibrate the sensor, and I THINK it calibrated. But I don't know for sure. It's reading 14.9 (shouldn't it be 14.7?) on the guage with the motor not even running so it isn't calibrated perfectly which bothers me but whatever. I will fix that later.
Many other things came up. Will post back later. Need to go shopping for some bolts.
#142
#143
Well guys, today completed my build. This is not something that can be done if:
1) You have never worked with HPT
2) Never used a tap
3) Never installed a supercharger before
It's really disappointing, but I'm gonna call it quits and take the car to a local shop that deals with Ecotecs on a regular basis. At one point, we used a torch to bend the dipstick (definitely not in the instructions) to make the Intake Manifold fit. There was grinding involved. Specific torques are required. Stuff I don't know, and the local stealership didn't want to give me.
I could go on for a really long time. I had one issue to deal with after another. Plus, classes start for me next week and I need it to WORK not sorta work.
I'll start a new thread when it's on, and all running.
2) Never used a tap
#145
yea bro....i can never do it myslef either da only thing i put on my car was my cai...when i get all my parts and have the money im gonna take to the local shop where i had all my mods done...
and i put the ss/sc wing on by myself but thats sumthing any idiot can do so dat dont count
Last edited by Cobalt2.4ss/sc; 08-28-2007 at 06:16 PM. Reason: Automerged Doublepost
#147
Yeah I have Rebel's instructions. Personally, I don't think they were as clear as they should have been but Rebel claims that their instructions have been given to others and they are doing fine with them.
I was about 60% done with everything when I realized I didn't have the time to finish it by the end of today and running reliably for me to go back to work tomorrow and classes on Tuesday.
I have HPT but have never used. I got to the part where you change the injector size in there but after that I would have no idea what to do.
#148
#149
See I'm not even sure if the LC-1 is working properly. My ground was messed up when I first hooked it up, so it went half way through the calibration cycle and then it shut off when I bumped the ground and it unplugged. I know, it wasn't supposed to be a permanent hookup. It was supposed to be temporary only for the LC-1 to calibrate itself then I would permanently install the power and grounds where I wanted them.
Now, the guage is reading 14.9 with the motor off and the sensor in free air (not in the bung). I'm going to go out on a limb here and say that it's ok because atmosphere is 14.7 so it is off by .2 . I bet if I recalibrated, I would get it down to 14.7. Correct me if I am wrong.
