2.4L Throttle Body Dimensions
Old Feb 20, 2007 | 03:57 PM
farfrmnormal's Avatar
Anyone know the TB dimensions for the 2.4L - curious for Intake development.
Old Jul 22, 2012 | 02:16 PM
iToastie's Avatar
Bump from a grave.. need this answer too
Old Jul 22, 2012 | 08:35 PM
noorj's Avatar
Nice sig......
What dimensions do you want? The inlet is 64mm diameter and the outer diameter is 72mm
Old Jul 22, 2012 | 08:54 PM
iToastie's Avatar
Do 2.4 TB's kinda curve in from the outer side? The diameter changes as it hits the butterfly valve on the one I got from someone, trying to see if it's a 2.4
Lmao.. now I see why you said nice sig...
Old Jul 22, 2012 | 09:27 PM
noorj's Avatar
You are correct, they have a slight angle before the throttle plate. Just measuring it is the easiest way, I'm not sure what the 2.2 tb's are though.
Old Jul 22, 2012 | 11:40 PM
iToastie's Avatar
I actually finally found the part number, it's so damn small and on the side of it, at the very bottom. But a quick search reassured me it's a 2.4l. Thanks for your help, as measuring it helped me too
DarrenGC
Dec 24, 2021 01:55 PM
Oct 13, 2015 09:32 PM
SSLOW06
Oct 1, 2015 07:21 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
