2nd o2 sensor...
Old Apr 4, 2009 | 01:50 PM
hoffa's Avatar
2nd o2 sensor...
is there really a purpose for the 2nd o2 sensor on our cars?
i've been running the p0420 code now for 2 years w/out any problems
asking cuz i'm thinking about using its as a spot to throw my wideband sensor in... easier than drilling/welding a new hole
Old Apr 4, 2009 | 01:55 PM
Steven Flit's Avatar
it let's you know if your cat is working properly... i took mine out a while back and just turned off the cel in hpt...
if you have a cat, that second bung wont do you any good for a wideband plug in. you need to have the bung welded after the 1st 02 sensor, before the cat, to not sku the readings.
Old Apr 4, 2009 | 02:48 PM
hoffa's Avatar
i heard that... i wonder how scewed it will be.
are we talking scewing like if my real afr is 12.1, it'll read like 10.1? i can do a 2 pt calculation in my head much easier than making a new hole
Old Apr 4, 2009 | 04:22 PM
I can't give you an exact answer as to what the actual afr may be...
but I do know placing a wideband after the cat will completely sku your readings.
go to a exhaust shop and spend 20 bucks for them to install a bung for you. Make sure it's PRE-CAT!
Old Apr 4, 2009 | 04:31 PM
hoffa's Avatar
well after looking more closely...
the wideband sensor needs to be ~18in downstream from the header right? taking that into account, there's no place pre cat to make a hole, the downpipes on these are header connection, flex, 1.5-2in of pipe and then cat...
the only place pre cat is pretty small...
Old Apr 4, 2009 | 04:33 PM
Rodimus_Prime's Avatar
get a new downpipe that allows you to do it pre cat
what hdr/dp do you have? I was under the assumption that the lsj, 2.2s, and 2.4s all have the same hdr/dp
haha, or that...
I had the exhaust shop fab me a complete Dp
Last edited by Steven Flit; Apr 4, 2009 at 04:33 PM. Reason: Automerged Doublepost
Old Apr 4, 2009 | 04:48 PM
hoffa's Avatar
aftermarket... xtc 2.5 w/ cat from colbalt addiction
Old Apr 4, 2009 | 09:34 PM
mmcgee123's Avatar
I have a zzp 2.5 catted dp I did mine right before the cat works perfect its about 19inches from head exhaust ports
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Fearedbynone
Apr 14, 2016 03:25 AM
Jan 12, 2016 12:01 AM
riceburner
Oct 2, 2015 05:47 PM
Sep 27, 2015 08:53 PM
