Airbox mod
Old May 22, 2008 | 10:50 PM
Dunkinuts's Avatar
Airbox mod
........wow......
the sound is crazy, go past anything half throttle and its deep. but you drive normal and it sounds fairly stock.
oh i am not sure if the 07 and older have this but there is a bolt that is hidden near the bottom of the airbox below the body but above the fender lining. i hate that thing. i have to heat a knife to cut through the "bracket" nothing else would fit.
I will get back to you on MPG b/c i have a 1/4 tank left and i am going to play
Old May 23, 2008 | 12:02 AM
Apcsox's Avatar
yea, there is a major audible difference when you pull that thing out
Old May 23, 2008 | 12:06 AM
zackss's Avatar
i still need to do this
i'm like the only one who hasn't had it done
Old May 23, 2008 | 01:15 AM
Panici's Avatar
Umm, WTF?
Are you guys talking about the silencer under the airbox?
Anyone have a writeup?
Old May 23, 2008 | 01:18 AM
EceSSiveMod's Avatar
theirs a how-to on the airbox mod.......you take the stock airfilter out and replace it with a dryflow(recomended) and leave the bottom off.......boom a couple hp's and a loud s/c
Old May 23, 2008 | 01:21 AM
Panici's Avatar
Oic. Like this? https://www.cobaltss.net/forums/how-guide-43/how-mod-2-2-2-4-airbox-30926/
And basically create a short-ram intake that sucks in warm engine bay air eh? No thanks
Old May 23, 2008 | 01:27 AM
well......no.....either way its going to be the same...so its either keep your stock intake....or add a 45 dollar filter and get about 3-4 hp......or spend 240bux and get like 7hp
the air is going to be hot either way....the benefits of the filter are more airflow for not alot of money....the benefit of a real CAI is that the air will be a few degrees less...and the diameter of the tubing is bigger so ull get more airflow
Old May 23, 2008 | 01:29 AM
zackss's Avatar
Originally Posted by Panici
Oic. Like this? https://www.cobaltss.net/forums/showthread.php?t=30926
no
the air intake on a 2.0 is much different
https://www.cobaltss.net/forums/how-guide-43/airbox-modification-3890/ like this
it's basically the same thing as a cold air intake
Old May 23, 2008 | 01:30 AM
^i was gonna say that next u beat me to it haha
Old May 23, 2008 | 01:31 AM
Pyros777's Avatar
"Cobalt SS Network > Engine Technical Discussion > 2.4L Performance Tech"
Old May 23, 2008 | 01:34 AM
zackss's Avatar
didn't even see that
good eye this thing needs moved
Old May 23, 2008 | 08:17 AM
Dunkinuts's Avatar
^^^ ummm i am a 2.4L
but not i just need to piece together some intake tubing and i have a cheap effective intake.
bigdeertz
Nov 17, 2016 09:41 AM
Tdubbs
Oct 13, 2015 02:31 PM
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
