Another Supercharged 2.4L LE5
Old 06-19-2017, 11:18 AM
  #76
royce777's Avatar
Originally Posted by HGT
Thank you... It will look better once I get the wiring recovered with split loom. I am leaving it open until my TMAP shows up. Bummer that was bad but much of what I received in my kit was.
where did you get your kit from?
royce777 is offline
Old 06-19-2017, 11:19 AM
  #77
Henry3959's Avatar
I'll tell you off line.
Henry3959 is offline
Old 06-19-2017, 11:32 AM
  #78
Henry3959's Avatar
After having everything rewired, I found the dead TMAP and had to run a wire back to the MAF's IAT. Looks like hell now. I will re-loom it all once that part is in.
The new vacancy from the air box is just screaming to be filled with the overflow tank
Old 06-19-2017, 11:30 PM
  #79
Henry3959's Avatar
Two new side effects of the Supercharger install.....
It makes this eerie whine at full throttle and the front tires slip....
Old 06-20-2017, 08:56 AM
  #80
Having fun already i see
Slowbalt2000 is offline
Old 06-20-2017, 09:29 AM
  #81
WICobaltSS's Avatar
Sorry to hear about the issues with your tires! Lol. Did a helluva job on the build! She looks great!
WICobaltSS is offline
Old 06-20-2017, 11:02 AM
  #82
Henry3959's Avatar
Yup... one thing leads to another...
Old 06-20-2017, 12:57 PM
  #83
jdbaugh1's Avatar
The LE5 Cobalt has the F23 transmission as well right? If it does I'm sure you may have experienced some nasty wheel hop like is common with these setups. Just FYI if you didn't know Powell sells a rotated engine/trans mount for the front and it helps immensely. That mod combined with LCA with trailing spherical control arm bushings completely eliminated the problem for me.
jdbaugh1 is offline
Old 06-20-2017, 12:58 PM
  #84
royce777's Avatar
He is an auto trans
royce777 is offline
Old 06-20-2017, 01:01 PM
  #85
Originally Posted by royce777
He is an auto trans
That being said the LCA will def help plant the power and likely keep things from getting fubared up
ECaulk is offline
Old 06-20-2017, 01:03 PM
  #86
jdbaugh1's Avatar
He is an auto trans
Well never-mind then. I actually remember him saying that now that I think of it.
jdbaugh1 is offline
Old 06-20-2017, 02:25 PM
  #87
Henry3959's Avatar
No wheel hop in those tire tracks... I built the front chassis before the engine.
Old 06-20-2017, 04:52 PM
  #88
jdbaugh1's Avatar
Iirc the automatic actually sits in there like it should and doesn't have the problem that we do with the F23. Wheel hop was so bad it would do it every time the tires started to slip on a launch and violent too. That is why I always try and tell F23 people who are adding power.
jdbaugh1 is offline
Old 06-20-2017, 04:57 PM
  #89
Henry3959's Avatar
I would be miserable if this had wheel hop... what a way to destroy parts.
Old 06-22-2017, 03:14 PM
  #90
Henry3959's Avatar
My MAF died quickly after relocating it to the CAI. Started randomly setting codes then finally quit all together. Maybe it was just a coincident but with a flaky TMAP (which my new one is out for delivery), you probably already know what happens when the CEL for the TMAP sets with an already dead MAF. That wheel well is not a cool place for the intake until there is air flow, in fact it appears to be hotter then the way I had it NA.
I think I am going to but some sort of duct in the bottom splash shield that will keep out water but let air flow. My hood ram air thought is starting to sound better every day.
Old 06-22-2017, 04:29 PM
  #91
Put a hydroshield on the air filter
Old 06-23-2017, 01:32 AM
  #92
Henry3959's Avatar
Key on Engine off I'm at 11.5 psi. 3.2 psi below sea level.
So far it will make just over 8 psi of boost on this 2.4L. Room for a smaller pulley
Old 06-24-2017, 10:18 PM
  #93
Henry3959's Avatar
Split my wiring looms and moved everything I could to the left. Only thing I left on the right was the VVT solenoid wiring and Transmission output shaft speed sensor. Redid all the split look also. Finally a deserving bath.
Old 06-25-2017, 10:07 AM
  #94
WICobaltSS's Avatar
DAMN!!! She turned out great! I wish my 06 looked that clean from the inside and out. Great job on the build! Any plans on lowering the car?
Old 06-25-2017, 01:29 PM
  #95
Henry3959's Avatar
Thanks... I would like to but I have a problem getting into my driveway now.
Old 06-27-2017, 05:28 PM
  #96
Henry3959's Avatar
I put on a temporary clear breather hose to see how well the PCV is working before doing something permanent. So glad I ported the intake gasket so it still functions and took the valve apart and cleaned it.
Old 06-28-2017, 01:10 PM
  #97
6772owner's Avatar
I love this build, I recently purchased an LE5 SS car and would love to do what you did. Im in CO also, any tips on sourcing parts? Should I just buy the ZZP kit?
6772owner is offline
Old 06-28-2017, 01:23 PM
  #98
If you have the cash you can buy the zzp kit, or if you don't mind looking for used parts then check the classifieds here or facebook.
Snail_SS is offline
Old 06-28-2017, 01:29 PM
  #99
6772owner's Avatar
Ok thanks, the kit doesnt seem that expensive after you look for all of the individual pieces. I need to look into the matter more closely. I appreciate the assistance!
Old 06-28-2017, 01:32 PM
  #100
The kit will be alot cheaper if you go the used route but then again if you want everything new or fast zzp is the way to go
Snail_SS is offline
