Boost Leak :(
Old May 31, 2008 | 11:34 AM
Turbo06Sedan's Avatar
Boost Leak :(
So...I got a bitchin boost leak. it sounds like a whistle..or a little girl scream.
and..i cant find it..which pisses me off.
Its probably for my boost gauge.
Thought i'd share.
Old May 31, 2008 | 08:47 PM
celicacobalt's Avatar
damn, mine last 2 boost leaks were at my #2 injector and intake manifold gasket. did you try the choke cleaner trick yet on your injectors and manifold?
Old May 31, 2008 | 08:52 PM
Red2.4SS's Avatar
Shitty!
So far no problems here!
Hope you find the leak!
Old May 31, 2008 | 09:13 PM
08sport's Avatar
dang... i didn't know we had so many 2.4l turbo'd guys.... now i feel EXTREMELY slow..
Old May 31, 2008 | 09:32 PM
Darkmanx's Avatar
lol last car i had that had boost leak i had to sell it because i couldnt find he ****.
Old Jun 1, 2008 | 12:13 PM
Im pretty sure its the way i rigged up my boost gauge.
That shitty plastic nylon tubing is well...shitty.
So i put teflon tape around part of it to seal it to the hole in the nut for the gauge, then i put a slightly larger vaccuum tube which the nylon tube fit right into it pretty snug.
So i think i'll go through the motions today.
I'll have to check out my #2 injector to make sure my o-rings are still cool.
My boost is all over the place though.
It peaks @ 10psi, then drops to 8psi.
so im sure its a boost leak. plus the faint sound of a whistle type noise.
Old Jun 1, 2008 | 12:18 PM
BIG-DAVE's Avatar
where can i find the orings for the injectors and also the oring for the sleave that covers the injector i have 2.2
Old Jun 1, 2008 | 12:21 PM
theres an o-ring on the injector itself, then theres one actually in the seating as well.
Your better off calling or going to a dealership.
Old Jun 1, 2008 | 12:37 PM
BIG-DAVE's Avatar
yea i went to the dealer that would only sell me it as a kit with injectors , etc.
Old Jun 1, 2008 | 12:39 PM
im sure its just a universal o-ring. get the size of it...and voala.
Old Jun 1, 2008 | 04:01 PM
pjk91's Avatar
i had a similar problem with my coils. theres an oring there, and the dealer wanted to sell me a new ignition and im telling the dude, no no man, i need an o-ring. supposedly they aren't sold separately, so i went to home depot and got one there in the plumbing dept. works good.
Old Jun 1, 2008 | 05:59 PM
Ya, O-Rings are O-Rings. Cost a few dollars for a package of 20.
You should be able to get them from autozone or any other parts store.
GM is kinda weird like that, back when i was going to do the dual exhaust cutout, i wanted a stock SS 2.4 exhaust tip, and they told me that it comes paired with the muffler only.
Old Jun 4, 2008 | 10:36 PM
I had to buy the embossment o rings as a 1 piece with the rubber o ring and embossment for like 420 from the dealer.
Old Jun 5, 2008 | 02:09 PM
i found my boost problem, it was the way i rigged up my boost gauge. Part of the vinyl tubing pinched, which didnt make a nice seal.
so i cut it, replaced it. and zip tied the **** out of it.
great stuff now.
Old Jun 8, 2008 | 06:13 PM
What PSI are you at on the gt2860rs?
Old Jun 10, 2008 | 07:23 PM
Zach06CobaltSC's Avatar
(this is turbo06sedan). Im at 8 on some gears, 10 on others.
Old Jun 11, 2008 | 10:32 PM
wow, i never noticed different ammounts of boost for each gear. i have noticed lower boost in hot and cold weather though.
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
n20saturn
Sep 30, 2015 12:26 AM
