Boosted 2.4s which map sensor are you using?
Old Mar 23, 2012 | 10:57 AM
DCOBALTSS's Avatar
What would be the difference between the 3 bar map and the 2.5 bar map
there is 20$ difference the 3 bar is at 29.99 and 2.5 at 49.99
if i get the 3 bar would it still be ok?
Old Mar 23, 2012 | 01:59 PM
hoffa's Avatar
iirc, someone on here stated that we could not use it.
go 2.5. try to find on on here for cheaper or a bone yard.
Old Mar 24, 2012 | 06:09 PM
DCOBALTSS's Avatar
Thanks
Old Mar 24, 2012 | 06:13 PM
nhanson's Avatar
2.5 is easy to wire in.
this is the connector needed
Home ť Shop ť Connectors / Harnesses ť Bosch ť 4-way sealed Plug Bosch BSK Connector Pigtail for Bosch MAP Sensor
Old Mar 24, 2012 | 06:20 PM
Cherry GT's Avatar
2 bar MAP, GM# 12580698.
I believe the peeps that use a 1 bar have to scale the MAP tables differently ???
Old Mar 24, 2012 | 07:03 PM
elecblue06's Avatar
this however theres a new PN for it through gm.. but that is the one zzp ships thats PnP
Old May 9, 2014 | 02:47 PM
cobalt_sport08's Avatar
Originally Posted by hhrfreek
I am using this one:
Home ť Shop ť Sensors ť Pressure Sensors ť Bosch 2.5 Bar TMap Map Sensor with IAT
I spliced the temp wires from the MAF so I just read IAT2 now. This sensor mounts in the stock location on the top left of the IM.
Sorry for the thread revive but I want to know if the wiring diagram is good for the 2.4 stock maf sensor. I've read that some mafs are different and black was actually my black and the tan is my tan on my car.
Thanks!
Old Jun 13, 2014 | 10:05 PM
Cherry GT's Avatar
My 07 2.4 iat wires at MAF are tan and tan/black.
I'm getting ready to hook up the lsj 2.5bar map, just trying to make sure.
Old Jun 15, 2014 | 11:28 AM
I figured it out but I can't get my IAT2s to read
Old Sep 29, 2014 | 09:56 PM
Cherry GT's Avatar
HELP MEEEEEEEEEEEEEE !
I installed Saab intake mani and am using the LSJ 2.5bar MAP sensor with IAT.
I was told to make this change for the new LSJ map, engine-diagnostics-
MAP SENSOR LINEAR= 270.59kpa and
MAP SENSOR OFFSET= -3.30kpa.
I did a WOT 2nd gear pull and my MAP kpa reading is only 145kpa this at 11psi.......hmmmmmmm
Where as before with 2bar MAP at 10psi I got readings of 175kpa.... which makes sense to me but not the above.
what have I DONE WRONG ?
Old Sep 29, 2014 | 10:31 PM
  #36
26gen4's Avatar
Originally Posted by DCOBALTSS
Im tuned with trifecta too..
And sometimes i get a P0121 code, and my idle is ****. When im driving and go to a stop gear to neural, the idle would go down like 400 then bounce to 600 then 500 then like finally stabilize to approx 900
that really pisses me off..
do you guys know what could be the problem,
Yeah the tune...
Remote tune is never gonna be dead on, i'd ditch it and go with a local tuner
Old Sep 29, 2014 | 10:33 PM
  #37
26gen4's Avatar
pretty sure i'm using either a 3 bar or 3.5
Old Sep 30, 2014 | 06:47 AM
  #38
Cherry GT's Avatar
ANYBODY, ANY INFO ?
Thanks
Old Sep 30, 2014 | 05:36 PM
  #39
sandman's Avatar
you can rescale your map if you are using the stock sensor
Old Sep 30, 2014 | 11:24 PM
  #40
Cherry GT's Avatar
^^LSJ T-MAP sensor, not stock for LE5
Old Oct 6, 2014 | 10:19 PM
  #41
Mercer's Avatar
Soo I just installed my supercharger the car runs, but the map sensor readings stay at 79kpa no matter what the operating conditions are. I'm using the 2.5 bar map and running the iats through it. Any thoughts?
I have a 2007, 2.4L
I've wired it according to the drawing that gets passed around all the time. The only thing I didn't understand was the low reference from the maf sensor. Does it get spliced in with the stock low reference? Making the two low reference wires into one?
I read that all that is to be done is to cut the low reference from the maf and do nothing with it...
Old Oct 6, 2014 | 10:59 PM
  #42
Cherry GT's Avatar
My low ref signal is two into one and works fine. I have no unused wires.
Old Oct 7, 2014 | 04:44 PM
  #43
26gen4's Avatar
i have a 3 bar i can sell
Old Oct 14, 2015 | 11:33 PM
  #44
patooyee's Avatar
How are e67 users utilizing anything above 1 bar when the ve table ends at 105kpa?
Old Oct 14, 2015 | 11:42 PM
  #45
I think its just for the fact of seeing boost in the logs, everything else is maf
Old Oct 14, 2015 | 11:46 PM
  #46
patooyee's Avatar
MAF uses VE, VE uses MAP ...
Old Oct 15, 2015 | 01:24 AM
  #47
i think most people tune their cars "maf only"
i was reading a thread you were posting in over at hptuners forums and i realize while ve is impossible to completely disable, i believe most people live with stock ve tables on the base model cars.
pretty sure lsj has a regular style ve table
Old Oct 15, 2015 | 01:25 AM
  #48
also i saw that you added to the axis and cobaltssoverbooster described that this should work. I requested the beta and may be trying it out for myself shortly
Old Oct 23, 2015 | 11:12 AM
  #49
patooyee's Avatar
Have you figured anything else out about VVE? I have had ZERO success getting even a single word out of HPT tech support or forums. Starting to become disappointed in HPT.
Old Oct 23, 2015 | 12:07 PM
  #50
Its still in the beta stages so you cant expect it to really work how it should or expect great support.
I havent really played with it too much but it all seems to make sense for me anyway.
I read somewhere on hpt forums that changing the map and rpm boundaries doesnt affect the vvt parts of the ve equation so it wont work because of the different axes... I havent tried loading anything onto my car with it yet.
