Boosted 2.4s which map sensor are you using?
Old Oct 23, 2015 | 01:30 PM
  #51
patooyee's Avatar
That's kind of my point. If the VVE tool is the only place that changing axis is affected why bother at all with VVE? I don't think anyone even knows how the VVE tool affects the rest of the tune since all the rest of the tables will still stop at 105kpa. So if you re-scale your MAP to 2.5 bar or such will it throw off the rest of the tables? If so it would seem like sticking with the stock 1-bar MAP before any forced induction would still be the best solution for tuning.
Old Oct 23, 2015 | 01:33 PM
  #52
Rescaling the map to be able to read above 105kpa doesnt affect anything really. All of the tables that use map values will just interpolate based on the last cell. What tables are you talking about specifically?
I have an lsj map on my turbo 2.4
Old Oct 24, 2015 | 10:30 AM
  #53
patooyee's Avatar
VE correction factor only goes to 105 kpa.
I guess I can't find many other tables that use kpa ...
But I guess my bigger question is, if the tables only go to 105 kpa and adding a higher sensor doesn't do anything, why add the sensor?
Old Oct 24, 2015 | 03:16 PM
  #54
I think that changing he boundaries and axes does create a 2 or 3 bar system.
Right now i just use it to read boost
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
jmelton327
Sep 26, 2015 10:04 PM
