bore size
Old Jun 15, 2008 | 12:39 PM
bridfi's Avatar
bore size
how can i get a bore like the 2.4 in my 2.2? is it a different block? or different sleeves?
do the 2.4 pistons mate up to 2.2 rods?
Old Jun 15, 2008 | 02:16 PM
Red07SSNA's Avatar
2.2L...bore 86mm...stroke 94.6mm
2.4L...bore 88mm...stroke 98mm
2.0L...bore 86mm...stroke 86mm
Old Jun 15, 2008 | 03:04 PM
bridfi's Avatar
Old Jun 15, 2008 | 03:26 PM
Witt's Avatar
Its a different block and sleeves (L880 in the 2.4 vs L850 in the 2.0/2.2).
The rods will not interchange.
Old Jun 15, 2008 | 03:43 PM
bridfi's Avatar
thanks.
Old Jun 16, 2008 | 10:16 AM
LS6Rally's Avatar
but are the crank main journals the same. thne you could use a 2.4 bottom end.
Old Jun 16, 2008 | 07:34 PM
bridfi's Avatar
well i was mainly asking because there are some wiseco 2.4 ecotec pistons on ebay for $100.
but i have a 2.2 and i need 2.2 pistons.
just for fun, i used an engine displacement calculator to calculate my stroke (94mm) multiplied by my bore (94mm like i said just for fun) x 4 = 2.609 liters!
can anyone say 2.6 ecotec?
Old Jun 17, 2008 | 03:59 PM
bigworm's Avatar
wiseco makes pistons for the 2.2 in a 90mm, cosmetic has gaskets, that should give you alot of low-end torque and ~2.4L
Old Jun 17, 2008 | 06:32 PM
celicacobalt's Avatar
i wonder if we could bore the 2.4 out to a 2.5?
Old Jun 17, 2008 | 10:09 PM
bridfi's Avatar
leaving 1 mm cylinder wall thickness?
iirc, the 2.2 has an 86 mm bore cylinder sleeve w/ 91 mm outside bore.
this would be like suicide.
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
HEATON
Oct 16, 2015 07:21 PM
Oct 13, 2015 09:32 PM
nathan112i
Sep 30, 2015 07:12 PM
