Brake Dust?
well for cleaning id recommend the mothers powerball with their aluminum polish cream that way you can get a deep cleaning. i will be buying one this weekend i will let you guys know how it goes..
I don't know about the rest of you, but changing rotors and brake pads can lead to high costs till you find the right one and even then you will not completely eliminate dust. UNLESS.....you get Brake shields. Look on line for KLEEN BRAKE SHIELDS. No more dust on the rims. What a great concept and only one time cost.
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
Originally Posted by k2kwj
how hard are they to put on? because as much brake dust as our pads produce the shields would probably need to be removed and cleaned just as often as we have to clean the rims.
Each time you rotate your tires. Thats all. A friend has these on his Mustang and swears by them.
edit: http://www.kleenwheels.co.uk/
