Build my 2.4L
See http://www.alcoholinjectionsystems.c...c25/index.html
for the details. It uses the output of your Naturally Aspirated engine's MAF to run a progressive controller for the injection pump. With ten percent improvement in HP thats 15 HP for a NA LE5!!!
When I was a kid, water injection was the way to chop a half a second off the quarter mile ET of a small block chevy...
zzp header dp combo, tsudo catback.. ebay intake. and a tune will start you off...
no reason to spend extra money on things that really arne't going to get you much better performance..
and that way you might have some leftover for springs a stb or something
and getting someone to bore out your tb would be a good one too and if you can do it yourself it can be really cheap
Why would we need anymore?
You wouldn't really gain more HP...and you would have a touchier throttle...or you can get the mounts and make it hook better.
