A/C engine rev problem and sound
Old Sep 24, 2014 | 12:57 AM
trentonwayne's Avatar
Just noticed that when my A/C button is on or the recirculation button is activated that the engine revs oddly, but the RPM's don't change. Also when either of the two buttons are activated there seems to be a pressure release sound coming somewhere near the alternator. Any help or guidance would be great! thanks!
Old Sep 24, 2014 | 06:39 AM
jimbofug007's Avatar
From past experience it's just the ac pump kicking on and off. When you run defrosters it will turn on to get rid of moisture in the car. And the car will bog a bit when the pump turns on
Old Sep 26, 2014 | 12:15 AM
Is there a fix for this? Air is now not working. Makes the same sounds as before. Thanks guys.
Old Sep 30, 2014 | 08:35 PM
Fixed.
Was overcharged, just released the freon with a nail. Works great now!
brandon04
Oct 21, 2015 07:04 AM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
